I am using LR 4 and have a technical issue when using LR with another program. I was told to re-install LR. I have a disc for LR 3. How do I proceed?
  • January 16, 2015
  • 109 views
I am using Photo Mechanic with Lightroom 4.  I was asked to re-install Lightroom.  I have a disc for LR3.  How do I proceed?
Correct answer Jeffrey_A_Wright
Jaygorodetzer Photoshop Lightroom updates contain the full installer.  I would recommend downloading the Photoshop Lightroom 4.4.1 from Product updates.
Jeffrey_A_Wright
Jeffrey_A_WrightCorrect answer
Thank you, Jeff.  I just did what you suggested, but the issue was not resolved.  In PhotoMechanic, I select a quantity of images and mark them RED.  When I import them into LR, the RED usually follows the image, so that I know which ones to edit.  Now, perhaps since updating to OS X Yosemite (10.10.1), the color tag is not visible in LR.
I spent about 8 hrs on the phone with the tech folks at PhotoMechanic.  They think it might have something to do with LR preferences.
Any thoughts?
Jay G
Jeffrey_A_Wright
Jay G thank you for the update that you were able to download and install Photoshop Lightroom 4.4 successfully.
I would recommend posting any questions you have regarding the use of Photoshop Lightroom in the Photoshop Lightroom forum at Community: Photoshop Lightroom | Adobe Community.
