I need help! Problems by Installtion of Design Suite CS6
  • June 14, 2015
  • 95 views
When the installation arrives 80% the programm show me a window there I read "please quit follow application "SafariiCloudHist". But there is no other app open, the finder and the installationapp only. so I can quit the installation only. What can I do?
    Correct answer Ned Murphy
    The following might provide the info needed as it is a similar issue...
    Installation prompt to close SafariNotificati
    https://helpx.adobe.com/acrobat/kb/install-prompt-close-safarinotificati.html
    Ned Murphy
    Ned MurphyCorrect answer
