Jan 7, 2025 11:21 AM UTC
I NEED HELP SOLVING A STRANGE PROBLEM
Hello
I am from italy and for the christmas vacations i travelled to the United States, bringing with me my Mac Pro 13", during my stay i have never opened it nor used and two days ago when i came back to Italy i noticed that in my trash i had a folder named Adobe with a subfolder named Assets with a short mp4 video that it's not mine. After that i also noticed that i have a new app (which i cannot use here in Italy) that is called Duplicate iphone. all of this is very strange and i am very afraid that my files have been taken. Do you have any tips on what to do? is there a way to find the original source of the Adobe folder?
Thank you
gupta shivangi
Jan 7, 2025 3:53 PM UTC
Hi @Tommaso_Montenesi9885,
We appreciate you contacting us.
I can see that you have an active subscription to Adobe Creative Cloud all apps since last 6+ years. The Assets folder you are referring to could be a location where you stored your raw files for any Adobe app.
^SG
kglad
Jan 7, 2025 2:17 PM UTC
the adobe folder could be something that sync'd and/or something someone shared with you.
Jan 7, 2025 1:23 PM UTC
I don't see what this has to do with Adobe other than you finding a folder with the name on it. I would perform a scan of your computer to see if you can find anything or go further if you believe your computer has been infected with something and consider restoring your system.
