Photoshop not compatible with my system (SSE 4.2 problem)
- February 11, 2022
- 1 reply
- 5558 views
It seams that i was to quick to celebrate my new acquisition. Creative cloud gave me 1 option to install Photoshop 22.2 (compatible, Photoshop 23.11 is not compatible). I've installed the version provided but when i tried to open it gave an error ("Error at loading of ippCV library"). It's my bad that i did not check the fine print regarding system requirements, so my Phenom 1100T (6 core) is good but it's missing SSE 4.2 and above. But then why did Creative Cloud gave me the option to install an older version, there was no incompatibility message (like the one from version 23.11) so i took it to face value.
I've checked here (https://helpx.adobe.com/photoshop/kb/known-issues.html#ErroratloadingofippCVlibrary) and it suggested that i should install an older version of Photoshop (v21.x), but it seams that i don't have that option since the versions stop at v22.0 .
I see to paths here, either i have the option to install a compatible version (v21.x) or i'll be asking for a full refund since i can't use your Photoshop. I hope i can install an older version.
If there are any questions or you need additional information please let me know.
Mike
