Power PC problem. My Adobe Creative Suite standard will not load onto my new MAC
  • January 23, 2012
  • 5 replies
  • 1229 views
My Creative Suite standard will not load onto my new iMAC. Message is will not support a power PC product.
    Jeri H
    Adobe Employee
    Adobe Employee
    January 23, 2012
    Can you specify which version of Creative Suite you're trying to install? (for example, CS3, CS4, CS5, CS5.5)
    January 23, 2012
    Just says Adobe Creative Suite standard on the cover.
    It's for macintosh.
    Two installer disks, one Video Workshop training, one Resources and extras, plus 5th disk is Adobe Pagemaker.
    Training disk has 90047375 2/04 1.1 on the bottom of the disk.
    copyright info is for 2003, made in Singapore.
    No version info is obvious to me.
    Jeffrey_A_Wright
    Timnmyu it sounds like you have the original Creative Suite.  This version will not function on a Intel Mac running 10.7.  10.7 removed support for Rosetta which means you are no longer able to run PowerPC applications.
