Problem with Upgrading from Flash 8 to CS5.5
  • November 29, 2011
  • 1115 views
I just bought and downloaded the Adobe Flash CS5.5 Upgrade version, and I'm upgrading from Macromedia Flash 8 Professional.
I also just installed Flash 8 on my computer today, and entered the (legitimate) serial number, too. I had purchased that back when it was out, and I'm hoping to finally upgrade today so I don't have to use anymore trials.
When Installing the Upgrade, it said it could not find compatible software. How do I get it to recognize my Flash 8?
I'm running on a up-to-date PC with Windows 7.
I also assumed restarting the computer would work, but did not.
Correct answer Jeffrey_A_Wright
Knickolaus when I view our upgrade information it is showing Macromedia Flash Professional or Basic 8 should be accepted when you enter the serial number for the eligible product.
For the best assistance, I recommend our chat support at http://adobe.ly/tl8Vx7.  Our chat representatives can provide a personalized experience to resolve the issues you have described.
Jeffrey_A_Wright
Jeffrey_A_WrightCorrect answer
I actually did talk with a chat representative just moments after posting, and the issue was resolved.
Jeffrey_A_Wright
I am glad to hear that our support representatives were able to help!
