noahk19942006
Why does Adobe CC keep randomly signing me out while I'm using their products?
  • November 28, 2018
  • 705 views
Seriously, this is like every 5 minutes, and it's horribly disturbing to any type of workflow.  I'm signing in multiple times within seconds for a few minutes of work, repeat ad nauseam.  Any permanent fixes for this bug?
Correct answer Kanikas
Hi Noah,
We're sorry for the issue you are facing.
Kindly follow the steps shared in the link for help: Adobe Creative Cloud signs you out or asks you to sign in repeatedly
Let us know if this helps! Feel free to update the thread for any other issues.
Thanks
Kanika
Kanikas
KanikasCommunity ManagerCorrect answer
Hi Noah,
Thanks
Kanika
I had this issue for over 12 months! It was driving me insane.
After putting in a complaint to Adobe Senior Management (via LinkedIn) about the lack of support I was experiencing, I was finally able to get someone to remote into my PC to stop Adobe CC constantly signing me out.
The solution, reset your Windows 10 "hosts" file:
https://support.microsoft.com/en-au/help/972034/how-to-reset-the-hosts-file-back-to-the-default
We fixed this last Friday night and it hasn't signed me out since. Fingers crossed this is the solution I have been looking for, but will keep testing for the remainder of this week to be sure.
Justin
