I am not able to activate Acrobat 9 Pro using my Volume Licensing..It says serial number not valid
  • October 24, 2016
  • 436 views
I am not able to activate Acrobat 9 Pro using my Volume Licensing..It says serial number not valid.
It doesn't give me nlicese exceeded or any other error message.
But I am sure the serial number is correct.
    Correct answer alisterblack
    Use the volume installer available under your account on the licensing website - licensing.adobe.com
    alisterblack
    alisterblackCorrect answer
    kglad
    you need to use the correct installation file for your volume license.
    [moved from Installing, Updating, & Subscribing to Acrobat to Deployment for Creative Cloud for Team, Enterprise, & CS]
