I need help with licenses
  • February 13, 2023
  • 673 views
I need to do a license distribution or change DC to standard
Correct answer Ashish_Harrison
Hi @Testa5E15 you can create a package from the admin console and install it on the user's machine. Acrobat will automatically be converted to Standard or Pro according to the subscription.
Thanks!
Ashish_Harrison
Adobe Employee
Ashish_HarrisonCorrect answer
Adobe Employee
February 14, 2023
Thanks!
Regards,Ashish Harrison
Testa5E15Author
Thx, i will try it.
Kevin Stohlmeyer
Hi @Testa5E15 You'll need to contact your Adobe Support team through the Support tab on your Admin console. They can assist you with your specific licensing.
Testa5E15Author
THX
