Flash on chromebook not even showing built-in microphone or camera... HELP.
  • March 4, 2016
  • 5080 views
So here is my problem.
I just bought a new ACER Chromebook 15, and I think that it's great, but my flash player isn't working properly!
There is a built-in microphone and camera in this unit, and the ability to link with my USB microphone.
And when I go to the audio settings, both microphones show up perfectly. As such:
HOWEVER
when trying to record from flash, it doesn't even show up with the built-in parts.
It looks exactly the same for the mic and camera sections.
Please help me. I really need this to work, or I need to know if I need to return this device and get a new one. It's a chomebook so I can't uninstall. I've tried restarting, disabling and enabling flash again, I've tried updating it - but I can't. And I've tried everything I can think of (or find online) in the settings!
Thank you so much for your help.
Please reply if you can.
Please go to below link and click on check now button to see the flash player version:
https://helpx.adobe.com/flash-player.html
Also please upgrade your chrome browser to latest.
Check on other browsers and see if the issue exist.
Hi there Kratika Agarwal,
Here is what shows up:
Unfortunately, on chromebook I cannot use any other browsers, or even attempt to download an update of chrome as it claims to update automatically.
I am just a little frustrated, as I used this function perfectly on the chromebook that I had before this, but it got water damage, so I bought this new one today and it isn't working. It's part of my job, so this is really setting me behind...
Thank you so much for your help, and I hope you may have another idea.
jeromiec83223024
Thank you for your detailed, prompt and informed answers. I am going to assume Google is already aware of the issue. The allow camera/mic dialogue or input selection just doesn't come up on ChromeOS Dev/Beta/Canary and I can accept that not everything is supposed to work in those stages.  I am hopeful I'll be able to work on http://api.duobeiyun.com/  conferencing for work one day and enjoy android apps at the same time. For now, I am not getting the most out of my touchscreen but at least I am getting a paycheck! Thanks again
Again, this is intentional behavior in Chrome, not an issue.  I don't believe that the plan is to allow end-users to override those controls.
The most productive course of action (and the one Google intends) is for you to complain to your conferencing provider about the fact that their service no longer works in Chrome.  This, in turn, encourages the Content Provider to change their content to protect your privacy.
