질문
Internal Error 8004, 6965356, 4565475, 5303539. FrameMaker has detected a serious problem and must quit.
  • September 6, 2016
  • 2 답변들
  • 288 조회
Dear Team
I'd like to reinstall FrameMaker8 on my computer (Windows 7 system). However, after I uninstalled the software and installed it on the same computer, I can no longer open FrameMaker8 and got this error.
After consulting the support team, I used the Adobe Creative Cloud Cleaner Tool to remove installation records and reinstalled FrameMaker8, following the instructions here at Use the Creative Cloud Cleaner Tool to solve installation problems . Unfortunately, this didn't work. I still cannot open FrameMaker8.
Would you please help me with this issue? Thank you very much.
Best regards
Sue
    이 주제는 답변이 닫혔습니다.
    2 답변
    Jeff_Coatsworth
    You should contact Adobe Support - those error codes don't mean anything to us mere mortals on the forums ;>)
    Bani Verma
    Moving to Adobe FrameMaker
