Artboard edges, anchor points and bounding box are grey and barely visible
- October 17, 2021
- 5 replies
- 8865 views
After the latest update I am having issues with Illustrator. When an item is selected, the bounding box is not blue as it was before, but light gray and therefore almost invisible. Anchor points as well. The artboard edges are also barely visible. I can't even tell which artboard is selected at the moment. Bounding box, edges and artboard are all marked as shown in the view panel. Any ideas? I am attaching a screenshot for reference.
Thank you!
