Extreme lag when simply selecting object - Macbook Pro M1 Max
- May 1, 2022
- 7 replies
- 5823 views
I am experiencing extreme lag in Illustrator on my Macbook Pro M1 Max with 32GB of RAM.
When using the selection tool to simply click objects, there is an extreme amount of lag and delay.
Please watch the attached video to see this lag in action. When selecting an object I often get the spinning wheel. After clicking an object to select it, and then moving the mouse, the object gets dragged to a new location.
If I drag a selection over the object, or click and drag the objects, they function correctly without lag.
Can anyone help me? I don't know what else to do. I've restarted, uninstalled, reinstalled, and disabled GPU Performance. No luck.
