해결됨
Using dual monitors. Can't move Adobe CS6 frame to right monitor.
  • May 12, 2012
  • 19 답변들
  • 73102 조회
Is there a way, when using dual monitors, to move the whole CS6 frame to either monitor? Right now it's just cemented to my left monitor, and I want it on the right.
이 주제는 답변이 닫혔습니다.
최고의 답변: tom-grant
Well, after some frustration and poking around I finally figured it out fellas.
In the Illustrator Menu Bar, click "Window" and then "Application Frame". It seems that option unchecked will leave the application "fixed" to your primary monitor. Checking it will place the application in a "free-form" window that you're free to move around.
Thank goodness!
19 답변
THANK YOU, Tom-grant!!! Gees, I was getting really mad with not being able to figure out how to get this back and finally searched and found your answer -- you averted a total melt-down here!!!!  😉
for me, unchecking Application Frame is what allowed free form movement. I'm in AI 2021, so perhaps it's been modified in newer versions?
THANK YOU!!!!
thanks! this is very helpful!@tom-grant
Grateful thank you!
Thank you so much. I've been dealing with this for some years now.
WHERE IS THIS ON Creative Cloud! Ugh, these steps don't exist.
brilliant that you. this has been driving me mad for weeks now.
Thanks much!!! You are the best!!!
sijo_james
Thanks , verymuch helpful
