2 Problems (1 Failure) were found
- June 30, 2024
- 2 replies
- 772 views
I am having a serious issue with exporting a document with about 8 links. This is a critical failure and I cannot diagnose any issue because the task alert is not specific:
I cannot identify any elements on page 5 that would be causing a failed export. When I delete the spread, it just tells me that the next one has the critical failure.
This is really bad and I can't export my project!
