Danny Bae
Jul 23, 2024 7:20 AM UTC
Burmese output issue on using Section Marker and Running Header
I created a Burmese manual to be written with Burmese unicode enconding and found an error on the texts to be generated by Section Marker and Running Header features.
<figure 1>
<figure 2>
Problem is:
  1. In figure 1, the blue-colored box is the heading to be input directly and the red-colored box is the bookmark to be generated automatically by the Section Marker feature.
  2.  In figure 2, the red-colored box (upper one) is the heading to be generated automatically by the Running Header feature.
  3.  The blue-colored box is correctly displayed but the red-colored boxes are represented INCORRECTLY. I tried to change a few of settings such as the fonts to fix it, but there was no change.
Is this a bug of InDesign?
Danny Bae
Danny BaeAuthor
Jul 24, 2024 2:02 AM UTC
I did more tests corresponding to this issue and found that same problem occurred on using other placeholder features such as Custom Text of Text Variables feature. (Fortunately, there was no problem on the text to be automated by the cross-reference feature.)
