Hot to fix strange behaviour of PageNumberOnly cross references
  • March 24, 2019
  • 740 views
I put few cross references in one paragraph.
InDesign does not fill whole line when I use "page number only" format for references.
If I use some static characters in format, everything is ok. If i place <pageNum/>, it became wrong.
It seems that <pageNum/> has some kind of "virtual" width about 3-5 characters.
Is there a way to make it work correct?
Images, video and sample file
Correct answer fotomirk
I've noticed that changing paragraph's justification composer to "Adobe World-Ready Paragraph Composer" solves the problem!
fotomirkAuthorCorrect answer
Barb Binder
Hi Fotomirk:
This appears to be an issue with InDesign x-refs, and the second one reported today.
Lines wrapping when they should not
After this thread from Feb 1 (Re: Cross Reference Not Flowing Correctly ) a bug report was logged here:  Cross reference takes more space than its text – Adobe InDesign Feedback.
Adding your vote and a link to this thread will help draw the InDesign team's attention to the matter.
~Barb
fotomirkAuthor
Thank you for your note. I've placed a vote for the bug report.
