Index panel reference entries missing after document conversion?
  • November 1, 2021
  • 128 views
I have returned to work on a book after several years away from it. For some reason Reference entries in the index panel no longer appear. The index updates correctly-so they are somewhere, but I do not have access to the actual reference items in the index panel. Is this after the recent file conversion? I really am not anxious to reconstruct the entire index and am hoping someone can set me straight.
    Peru Bob
    I've moved this from the Using the Community forum (which is the forum for issues using the forums) to the InDesign forum so that proper help can be offered.
    fitserAuthor
    Should have mentioned working in indesign 2022.
