SuzzyFlamingo
Jul 29, 2025 8:04 AM UTC
Need help with another script and general question about scripting
Hi, Dear Friends!
I am trying a different function this time. To scan the text frame and any string formatted with the char style "sidenote", it extracts that text and creates an anchored text box in the margin with that text (different locations for even and odd pages).
Chat GPT gave me this:
#target indesign
(function () {
var doc = app.activeDocument;
var styleName = "sideNote"; // The character style for the sidenote text
// Ensure the cursor is in a valid text frame or text story
if (!app.selection.length || !(app.selection[0] instanceof TextFrame) && !(app.selection[0] instanceof Text)) {
alert("Please place your cursor in the story to start scanning.");
//return;
var sel = app.selection[0];
// If the selection is a TextFrame, use its parentStory, otherwise use the selected text's parentStory
var story = (sel instanceof TextFrame) ? sel.parentStory : sel.parentStory;
// Loop through the story to find all text with the "sidenote" character style
var sideNotes = [];
for (var i = 0; i < story.texts.length; i++) {
var currentText = story.texts[i];
if (currentText.appliedCharacterStyle.name === styleName) {
sideNotes.push(currentText.contents); // Extract "sideNote" text
if (sideNotes.length === 0) {
alert("No text with the 'sideNote' character style found.");
return;
var page = sel.parentTextFrames[0].parentPage;
var isOddPage = (page.name % 2 !== 0); // Check if it's an odd or even page
var sideNoteText = sideNotes.join(", "); // Combine side notes with commas
// Create the anchored text frame in the appropriate margin (left or right)
var marginSide = isOddPage ? "left" : "right"; // Odd pages: left margin; Even pages: right margin
var marginTextFrame = createMarginTextFrame(page, marginSide, sideNoteText);
// Anchor the text frame in the main text flow
var anchorPoint = page.textFrames[0].insertionPoints[-1]; // Anchoring at the end of the page text
marginTextFrame.anchor(anchorPoint);
alert("Side notes placed successfully!");
// Function to create a text frame in the margin based on page type (odd/even)
function createMarginTextFrame(page, margin, text) {
var textFrame;
var marginWidth = 50; // Adjust this for margin width
var textHeight = 100; // Adjust for height of the side note box
var marginX = (margin === "left") ? 0 : page.bounds[3] - marginWidth; // Left or right side
// Create text frame in margin
textFrame = page.textFrames.add();
textFrame.geometricBounds = [0, marginX, textHeight, marginX + marginWidth];
textFrame.contents = text;
// Optional: Style the text frame
var textStyle = textFrame.texts[0].appliedCharacterStyle = doc.characterStyles.itemByName("sideNote");
textFrame.texts[0].pointSize = 8; // Adjust text size
textFrame.texts[0].leading = 10; // Adjust line height
return textFrame;
And it is telling me that there is no text formatted with that style. BUT THERE ABSOLUTELY IS!!!  ( I am getting really angry at ChatGPT for wasting my time!)
Is there a way to debug scripts step by step, similar to the macro editor in MS Word?
Thank you, and have a good day!
Susan Flamingo
Peter Kahrel
Peter KahrelCorrect answer
Jul 30, 2025 1:18 PM UTC
Sorry for that. I meant the correct anchored text box which are different for odd and even pages as i said before. Hope that clears things up
Ah, ok, I see. Here you go:
(function () {
  var frame,
      sidenotes,
      odd = app.activeDocument.objectStyles.item ('ATBOdd'),
      even = app.activeDocument.objectStyles.item ('ATBEven');
  if (app.selection.length === 0
      || !(app.selection[0] instanceof TextFrame)) {
    alert ('Select a text frame');
    exit();
  app.findGrepPreferences = null;
  app.findGrepPreferences.appliedCharacterStyle =
    app.activeDocument.characterStyles.item('sidenote');
  sidenotes = app.selection[0].findGrep();
  for (var i = sidenotes.length-1; i >= 0; i--) {
    frame = sidenotes[i].insertionPoints[0].textFrames.add();
    if (sidenotes[i].parentTextFrames[0].parentPage.side ===
        PageSideOptions.LEFT_HAND) {
      frame.appliedObjectStyle = even;
    } else {
      frame.appliedObjectStyle = odd;
    sidenotes[i].move (LocationOptions.AT_BEGINNING, frame);
Peter Kahrel
Jul 29, 2025 1:24 PM UTC
As Rob mentioned, chatGPT sometimes hallicinates (some euphemism!), though it often get very good results. It just depends on what it finds on the web. By the looks of it in your case it found various bits and pieces and cobbled them together.  Many times though there are much better solutions than are available on the web. What you're after appears to be a case in point.
Below is a pretty simple script. It can be simple because InDesign itself does most of the work through an object style. That style defines a spine-relative achored text frame with its width and vertical auto size set. So the script doesn't need to bother with figuring out whether you're on a left- or right-hand page or the size of the frame.
The script assumes the presence of an object style 'sidenote'. Select a frame and run the script. The attached InDesign file illustrates the object style.
(function () {
  var frame,
      ostyle = app.activeDocument.objectStyles.item ('sidenote');
    exit();
  var sidenotes = app.selection[0].findGrep();
    frame = sidenotes[i].insertionPoints[0].textFrames.add ({
      appliedObjectStyle: ostyle
SuzzyFlamingo
Jul 29, 2025 3:11 PM UTC
Wow! Actually works! Thank you!
Since you have been so kind, I will try my luck at another request:
I have two abchored text box style, one for (styATBOdd) odd pages (places it in the left margin) and one for even pages(styATBEven) (places it in the right margin)
Could you add that functionality that if it is on an odd page, it places it in the odd page text box and on an even page in the even page TB
Again thank you
Susan Flamingo
Peter Kahrel
Jul 29, 2025 7:28 PM UTC
That's certainly possible, but how do those styles differ? is it not possible to change the one style such that it works they way you want?
rob day
Jul 29, 2025 11:06 AM UTC
I am getting really angry at ChatGPT for wasting my time! Is there a way to debug scripts step by step, similar to the macro editor in MS Word?
Hi @SuzzyFlamingo , You would need an application like Visual Studio Code with the Extendscript plugin to debug—the learning curve is steep.
ChatGPF is hallucinating. There are a number of problems with the script. It doesn't do anything unless all the selected test is assigned your character style and then throws an error if it is:
