Kath-H
Printing Error: The Adobe Print Engine has failed to output your data due to an unknown problem
  • February 4, 2009
  • 12 replies
  • 22657 views
I've seen this before when placing some of the blizzard of pdfs of all kinds that land in my inbox into Indesign. I can't remember if I ever solved it, but one work-around has been to place the pdf, then export as pdf, place that into a new document.
It's not working this time though. The pdf in question was created in Indesign CS2 (4.0.5) in Windows, the Windows fonts are all embedded, I'm using CS2 Mac. Everything else prints fine to a variety of output devices.
Can anyone shed any light, is there more information I can provide?
It prints from Acrobat, which is what I'm doing, but not when placed into ID.
Thanks in advance.
    Kath-H
    Kath-HAuthor
    Possible solutions include a bunch that I can't try, such as issues with fonts or colour spaces, as it's a supplied pdf. Given the resolution of exported jpegs, exporting as such won't do. I suppose I could try converting to eps via Photoshop.
    This is weird one:
    >Solution 3: Change print options in the Print dialog box.
    >Make the following change in the Print dialog box:
    >If you print a section that contains only one odd page, deselect Even Pages Only.
    If you print a section that contains only one even page, deselect Odd Pages Only.
    Umm, if I was printing only an odd page, I wouldn't get very far printing even pages only, now would I?
    If I ever get to work through the snow, I'm going to look at this one first:
    >Solution 6: Remove OPI 2.0 comments from the PDF file.
    >Remove OPI 2.0 comments from the PDF file, place the PDF file into InDesign, and then print the document.
    >To remove OPI 2.0 comments, do one of the following tasks:
    >In Adobe Acrobat, manually remove the OPI 2.0 comments and then re-create the PDF file.
    It doesn't mean much to me, but it might be a plan. As I said, for this document it doesn't really matter, I can print from Acrobat, but if a placed pdf is only part of a document I could be in trouble.
    It's weird, one problem, all kinds of possible causes. If I'm being a pest, someone please say, otherwise I'll report back on which solution/workaround succeeds.
    Kath-H
    Kath-HAuthor
    OK, maybe no-one has experienced this. If it's OK I'm going to report what I find, in case anyone later has the issue and does a search in here.
    Google led me to a knowledgebase article http://kb.adobe.com/selfservice/viewContent.do?externalId=332622 (search the kb appears to be broken), and the following reasons are offered:
    *Printing to a non PostScript printer immediately after printing to a PostScript printer with Scale To Fit selected.
    *Cancelling a print job during the printing or spooling process.
    *Printing with damaged preference files.
    The first two don't apply to me, I tend to put off recreating preferences if I can, and other documents with placed pdfs are printing just fine.
    Other possible causes:
    *Printing a PDF file that contains OPI 2.0 comments.
    *Printing a gradient that contains spot colors from different color spaces.
    *Printing a tagged text file that uses out-of-range colors.
    *Printing without having selected a printer in the Chooser .
    *Printing with the Chooser open after making a printer selection.
    Chooser????
