PT Serif Pro bold shortcut does not work in InDesign
The PT Serif Pro bold shortcut (shift+ctrl+b) does not work in indesign. The underline (shift+ctrl+u) and italic (shift+ctrl+i) shortcuts work fine. And in Illustrator with this font (PT Serif Pro) there is no such problem. All shortcuts work.
The font is installed from Adobe Fonts. I reset all settings. I tried in 20.3 and 20.4. I even tried assigning shortcuts to other keys. Nothing worked.
If the problem is in the font itself, why does the shortcut work in Illustrator?
