Andreas Jansson
Script for exporting LAB Color swatch values to Excel (CSV)
  • October 15, 2019
  • 9493 views
Not sure this landed on the right place. Where is the scripting part of the forum? Was it deleted? All that work...
(This post is not a question.)
Below you will find a sample script for exporting LAB color swatches from InDesign. InDesign seem to have difficulties keeping thousands of swatches in its palette, so take care. A variant of this script made for Illustrator or Photoshop would probably have been a better idea.
	Script for exporting LAB colours from InDesign Swatches.
	Number, Name, L, A, and B columns semi colon separated.
	By Andreas Jansson, Code Combinations AB, Sweden, 2019.
	Description:
	First import a library of Pantone Colours so that they are present in the swatches palette of InDesign (you can export swatches from Photoshop, to an ASE file that is importable in InDesign).
	Then alter the path below to a folder of your choice and run this script with InDesign.
	The resulting file, I pasted into Excel.
var result = '';
for (var i = 0; i <= app.swatches.length-1; i++){
	var currentSwatch = app.swatches[i];
	if (currentSwatch.hasOwnProperty('space') && currentSwatch.space == ColorSpace.LAB){
		var val = currentSwatch.colorValue;
		result += i.toString() + ';' + currentSwatch.name + ';' + val[0] + ';' + val[1] + ';' + val[2] + '\r\n';
result = 'N:o;Name;Lightness;A;B' + '\r\n' + result;
var outPath = 'C:/temp/test/out.txt';  // Put an existing path here
alert(writeToFile (result, outPath));
function writeToFile(fileContents, destinationFilePath){
	var myFileOut = new File(destinationFilePath);
	myFileOut.open('w');
	// myFileOut.encoding = 'UTF-8';
	myFileOut.write(fileContents);
	myFileOut.close();
	return new File(destinationFilePath).fsName;
Roger Breton
Hi Andreas,
Thanks for the script. I need to tell you that, in v18.1 x64 on Windows, I had to modify your script by adding the "activeDocument" everywhere otherwise it would result "nothing". Here is the modified script that is working for me :
var result = '';
var Roger = app.activeDocument.swatches.length;
for (var i = 0; i <= app.activeDocument.swatches.length-1; i++){
	var currentSwatch = app.activeDocument.swatches[i];
	myFileOut.close();
It took me a while to figure the problem. Had to download and install VScode and Adobe's ExtendScript Plug-in (v2.0.3). Overall , very frustrating beccause there is no documentation around.
Roger Breton
Update: March 14 2024
I tried running the script from VScode, using Adobe ExtendScrip Plug-in installed.
The script returned nothing when ran against the current Adobe Illustrator document? Seems the the
currentSwatch.space
property does not exist in Illustrator?
But the scrupt will run fine against an Adobe InDesign open document since InDesign natively "honors" CIE Lab color model as far as swatch names are concerned.
Robert at ID-Tasker
currentSwatch.space
activeDocument - doesn't have swatches collecton - only document have - in Illustrator.
I'm not JS guy, but this should work:
var result = '';
var Roger = app.activeDocument;
for (var i = 0; i <= Roger.swatches.length-1; i++){
	var currentSwatch = Roger.swatches[i];
I need to get CMYK Swatch values into an Excel Spreadsheet. 5 Columns, Swatch Name, C, M, Y, K.
Does anybody have an Apple Script to do this? Or any other recommendations?
Andreas Jansson
My LAB version above script can easily be changed into any color space. Here is one for CMYK. Just change the local result path, and import the resulting csv file into Excel, after running the script.
You can use Javascript which is used for platform independent scripting in InDesign.
// My LAB version script can easily be changed into any color space. CMYK.
var result = '';
	if (currentSwatch.hasOwnProperty('space') && currentSwatch.space == ColorSpace.CMYK){
		result += i.toString() + ';' + currentSwatch.name + ';' + val[0] + ';' + val[1] + ';' + val[2] + ';' + val[3] +  '\r\n';
result = 'N:o;Name;C;M;Y;K' + '\r\n' + result;
// var outPath = 'C:/temp/test/out.txt';  // Put an existing path here
var outPath = app.activeDocument.filePath.parent + '/' + 'out.txt';
var resultFilePath = writeToFile (result, outPath);
alert('File path: ' + resultFilePath);
	myFileOut.close();
Robert at ID-Tasker
No dice after updating InDesign to 19.4 (I even copied the script and pasted into a new jsx).
I'll give it a try on one of my Intel macs when I get a chance.
@rob day thanks for your responses.
@Jeremy@M
Can you share your INDD file?
Good Day Everyone,
I am a new Adobe Photoshop and InDesign user and am looking for some help or direction. I need to import a color library using the color name and L a b values for a set of colors into my  inDesign Swatch Library. Does anyone know of an available script to do this? I saw a post from Mark that had the formatted spreadsheet to do this and it had the MacOS script but not the PC javascript. The requestor was using a Mac. If anyone could point me in the right direction or suggest a script to do this on my PC it would be greatly appreciated. My data is in the following format in excel.
Thank you!
NAMEL*a*b*
SWATCH 150.00-30.0020.00
SWATCH 253.00-32.0021.00
SWATCH 356.00-34.0022.00
SWATCH 459.00-36.0023.00
rob day
Hi @ColorDyeingMan2021 Save your csv named LabColors.csv to the desktop, and try this:
var path = File(Folder.desktop + "/LabColors.csv");
var cTable = readFile(path);
//split the table into an array of rows
var r = cTable.split("\n");
var doc = app.activeDocument;
var c, ns;
for (var i = 1; i < r.length-1; i++){
    //split the row into an array of cells
    c = r[i].split(",");
    ns = makeSwatch(doc, c[0]);
    ns.model = ColorModel.PROCESS;
    ns.space = ColorSpace.LAB;
    ns.colorValue = [Number(c[1]),Number(c[2]),Number(c[3])]
* Read a text file
* @param the file’s path
* @return the file’s contents
function readFile(p) {
	var f = new File(p);
	f.open("r");
	var x = f.read();
	f.close();
	return x;
* Makes a new swatch
* @param the document to add the swatch to
* @param swatch name
* @return the new or existingswatch
function makeSwatch(d, n){
    var s;
    try {
        d.colors.add({name:n});
    }catch(e) {
        s = d.colors.itemByName(n);
    return d.colors.itemByName(n);
Also, if the color channels are evenly incremented you wouldn’t need to load a spreadsheet—you should be able to increment the values in a loop
Hi rob day,
Thank you so much. I am not a programmer but was able to get the jsx file created (after a couple of tries and an error) and added as a script in InDesign and to try on the stored csv. Success!!! The colors and data values look great. I really appreciate this. One more question. If I wanted to store the swatches to a specific swatch library can /could I do that using this script? Or is this something I would do post importing? I want to be able to save a color library and share as an ASE file eventually.  I will look for more details on managing libraries and see if I can figure that out.
Again, thank you.This is gonna save me hours of time.
