"space between paragraphs using same style" disappears on reflowable epub
- January 22, 2023
- 4 replies
- 4621 views
This is a bit maddening, I'm publishing a book of poetry and just need spaced between the sections. Spaces between paragraphs is not an abstract function of written text but seems to be incredibly complex to accomplish. Orignally I just hit retun to show a space, as I do in word processing doc. Those spaces disappeared when I saved to epub. After digging I found that I needed to use paragraph styles above and below, did that and those spaces also disappeared. Then I found someone suggesting I use forced line breaks and that worked! Then someone else said that's bad form, and that I should use paragrpah styles. I discovered there's paragraph style "space between paragraphs using same style"...that's what I need! Applied it...disappeared. I've spent hours trying to get spaces between my paragraphs, please can someone tell me what I'm missing? Is there some setting I need to click to preserve paragraph style spacing in epub?
