White box showing up behind .ai file in InDesign. There should not be a white box. It should be transparent.
  • May 23, 2017
  • 9 replies
  • 36976 views
I have a vector logo that I downloaded from Brands of the World. Dropped it into InDesign on top of an image and there is a white box. So I opened it in Illustrator and made sure there was no white background on the image. I couldn't see one, so I copied the logo and dropped it into a new AI file to make sure there weren't any background layers or something from the original. Saved that and dropped into InDesign. Same deal. So I went back into AI and put a box behind the logo and colored it to make sure there was nothing weird going on with the logo. Sure enough, it's transparent. But I can't get it to be transparent in InDesign. And yes, I do have Display Performance set to High Quality Display. Any ideas why it would show transparent in AI and not in ID? Both programs are up to date CC.
Correct answer Frans v.d. Geest
Place the file and make sure to activate the import options: there you can turn on  the Tranparent background option.
Scott Citron
The other reason the the .ai file may appear with a white background in InDesign is if its creator failed to check the Create PDF Compatible File in the Illustrator Options Save dialog, shown here.
Hi Alison5CB4 and amoinette,
yes, there is a default option. It's in the Import Options if you use the Place command for an AI, a PDF or an InDesign Page. So if you want to change the background from opaque to transparent when using CC Libraries with PDF like graphics, first import a PDF file from your file system and change the Import Options to your desire.
Only then drag that item out of a CC Library.
Uwe Laubender
( ACP )
Thank you, but I am asking if there is a default setting, so that this will be the same for every ai, pdf, etc image that is placed in IND and I don't need to use import options everytime...
The answer is "no" if you think of a preference in the Preferences dialogs.
AI and PDF share the same import dialog. Let's see, there are PNG import options, that are a bit different, but I think, that's it. EPS, JPEG, TIFF or PSD have no option in that direction…
And it is also "yes", because checking this settings once in the Import Options defines it as default value.
( Until you have to trash InDesign preferences folder and files. )
Uwe Laubender
( ACP )
This same problem happens when placing an AI image using CC Libraries. There are no import options showing up when I place the CC Library item. Is there a preference setting or workaround?  BTW this didn't use to happen with AI files placed from CC Libraries and it's really causing me excess work to update old files.
Thank you,
Is there a default option that can be changed?
Worked like a charm. Thanks!
Gribbsss
That doesn't work for me. My Creative Cloud .png and .ai graphics load with a white background. I tried placing into InDesign directly (with transparency selected, same problem.
j2studio
Thank you! Waw driving me nuts. Shouldn't there be a global setting to allow transparent imports at all times?
BobLevine
It's a sticky setting.
Frans v.d. Geest
Frans v.d. GeestCommunity ExpertCorrect answer
THERE WE GO. That works. So odd. I've never had to do that before when dragging an image with a transparent background from the finder into an InDesign window. But now I know about that option. Thank you!
BobLevine
You're actually placing a PDF when it's coming in as an AI file. That choice is sticky so you shouldn't need to change it again unless you need the white background.
barbara_a7746676
Instead of copy and paste, try File > Place to place the logo into InDesign.
I wasn't copy and pasting. I was dragging from the finder into the ID window (same as file/place as far as I know)
BobLevine
Is the frame itself filled with white?
Nope....
