Color difference in Library and Develop
  • April 8, 2025
  • 1417 views
I know it's an common issue, but still couldn't find a solution to that. When I switch between the Library tab (all images have Standard previews) and Develop tab, they look alot different. When I export the images and they look like the Library preview. When I turn off in Preferences... the Use Graphics Processor, then Develop looks alike the Library, but the performance is drastically down.
[Moved from ‘Bugs’ to ‘Discussions’ by moderator, according to forum rules.]
Correct answer alvatr
So did you install the Studio driver?
Nvidia released a new driver three days ago – https://www.nvidia.com/en-us/drivers/details/243339/
Please post a screenshot of the Devices tab of the Color management dialog, like my screenshot here.
I also notice that LrC is installed to your G drive. If you're doing this to save space on C, you're only saving around 3.4 GB.
How much free space do you have on C, and what's the capacity of the drive?
I think I fixed it now, it was some weird settings on my monitor, that automatically chose it self, thats why it looked weird. Now the Library and Develop look even.
I have Lightroom on D, because on C I only have the OS.
Thanks for everything.
JohanElzenga
Check that you are using the latest version of your GPU drivers.
-- Johan W. Elzenga
alvatrAuthor
I've already installed the latest GPU driver.
Per Berntsen
If you have an Nvidia GPU, make sure to install the Studio driver (if available), not the Game ready driver.
