Configu.lua does not fix my rendering problem in Lightroom Classic
Some users have a had problem with the new Lightroom Classic in which images were not rendering in the Library module. The issue is documented in another thread. Users are directed to install a file config.lua and that has solved the problem for many users. It has not resolved the problem for me so I am starting a new thread.
I upgraded to LR Classic on my Windows 7 machine. I have reinstalled the software twice and verified my drivers are up to date but I still have the problem where the image will appear in the navigation window but not in the filmstrip or in the main Library panel. I thin I either have a bad version of config.lua and or I have another problem. When I examine config.lua with Notepad, here is what I see:
Tools = {
OldBackupImplementation = true,
In previous thread, it was stated "
The System Info dialog (Help > System Info) should display the config.lua flags entry as shown below:
Config.lua-Flags:
AgView.disableDirect2D = true"
When I check the system info reported in Lightroom here is what I get:
Lightroom Classic version: 7.0 [ 1140024 ]
License: Creative Cloud
Operating system: Windows 7
Version: 6.1
Application architecture: x64
System architecture: x64
Logical processor count: 8
Processor speed: 2.1 GHz
Built-in memory: 8139.6 MB
Real memory available to Lightroom: 8139.6 MB
Real memory used by Lightroom: 666.8 MB (8.1%)
Virtual memory used by Lightroom: 804.9 MB
GDI objects count: 632
USER objects count: 2289
Process handles count: 1206
Memory cache size: 14.9MB
Maximum thread count used by Camera Raw: 5
Camera Raw SIMD optimization: SSE2,AVX
Camera Raw virtual memory: 212MB / 4069MB (5%)
Camera Raw real memory: 214MB / 8139MB (2%)
System DPI setting: 96 DPI
Desktop composition enabled: Yes
Displays: 1) 1920x1080, 2) 1366x768
Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
Graphics Processor Info:
Check OpenGL support: Failed
Vendor:
Version:
Renderer:
LanguageVersion:
Application folder: C:\Program Files\Adobe\Adobe Lightroom Classic CC
Library Path: C:\Users\Sharon\Pictures\Lightroom\Backups\2016-09-17 1433\Lightroom 4 Catalog-2-2-2-3.lrcat
Settings Folder: C:\Users\Sharon\AppData\Roaming\Adobe\Lightroom
Installed Plugins:
1) AdobeStock
2) Canon Tether Plugin
3) Facebook
4) Flickr
5) HDR Efex Pro 2
6) Nikon Tether Plugin
7) ON1 Effects Standalone 10
😎 Show Focus Points
Config.lua flags:
Tools.OldBackupImplementation = true
Adapter #1: Vendor : 8086
Device : 116
Subsystem : 185d103c
Revision : 9
Video Memory : 1068
AudioDeviceIOBlockSize: 1024
AudioDeviceName: Speakers / HP (IDT High Definition Audio CODEC)
AudioDeviceNumberOfChannels: 2
AudioDeviceSampleRate: 48000
Build: 10.0x7
Direct2DEnabled: false
GL_ACCUM_ALPHA_BITS: 16
GL_ACCUM_BLUE_BITS: 16
GL_ACCUM_GREEN_BITS: 16
GL_ACCUM_RED_BITS: 16
GL_ALPHA_BITS: 8
GL_BLUE_BITS: 8
GL_DEPTH_BITS: 24
GL_GREEN_BITS: 8
GL_MAX_3D_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_SIZE: 8192
GL_MAX_TEXTURE_UNITS: 8
GL_MAX_VIEWPORT_DIMS: 8192,8192
GL_RED_BITS: 8
GL_RENDERER: Intel(R) HD Graphics Family
GL_SHADING_LANGUAGE_VERSION: 1.40 - Intel Build 8.15.10.2476
GL_STENCIL_BITS: 8
GL_VENDOR: Intel
GL_VERSION: 3.1.0 - Build 8.15.10.2476
GPUDeviceEnabled: false
OGLEnabled: true
GL_EXTENSIONS: GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_EXT_texture_snorm GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_draw_elements_base_vertex GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_compatibility GL_ARB_vertex_array_object
Can someone please verify that I have the correct content in config.lua and if so, suggest the next steps.
