Denoise problem producing weird artifacts in final result
Anybody else having problems using Denoise AI on lightroom? Seems like a great tool for concert photorgraphy where you usually have low light conditions most of the time, the problem is that for some reason once you export the photo the final result is not the same as you see in lightroom. It has some weird artifacts and color spots that were not there in first place.
Also, once you apply denoise to a photo seems like you can't go back to the original photo without denoise, even if you reset all the settings, still shows like denoise is apply to the raw image.
Here are the photo i see in Lightroom after applying denoise and the final result:
