Rikk Flohr_Photography
Distraction Removal: Dust (Camera Raw and Lightroom Classic)
This post applies to Camera Raw and Lightroom Classic.
Dust Removal is no longer in Early Access status and can be found in the Remove edit panel for Camera Raw & Lightroom Classic. Dust Removal helps with removing distracting spots on an image that may be caused by dust on a camera's sensor.
Once enabled, your image will be scanned, and any detected dust spots will be automatically removed using Content-Aware Remove. For refinement, you can select one or multiple spots to delete or refresh. Batch removal is also supported; simply select the "Dust" checkbox under "Remove" in the copy settings dialog.
Please note that scanned negatives are not in the scope of this feature at this time.
  • Dust spots on scans tend to be located in the focal plane, with the negative and very sharp, while sensor dust is typically positioned out of the focal plane and therefore not in focus.
  • Scanned negative dust typically appears as white spots on a darker background, whereas perceived sensor dust tends to appear as dark spots in lighter areas.
We would love to hear your feedback on Dust Removal! Please give it a try and let us know what you think:
  • How is it useful?
  • How could it be more useful?
  • What could we do to improve your experience?
Lisa Ngo, Product Manager
Also see this video by @brianmatiash where he demos the feature: https://www.youtube.com/watch?v=YwpUX4b6igY
Posted by:
193 commentaires
It sucks! Leaves spots, and if you select any area within the photo, the remove tool boundary shows
robinc36343182
Definitely not working for me. Smoke and mirrors.
Ken 24680
I tried the new Dust Removal tool in my Lightroom Classic. Although this sounds like a great feature, it did not work at all. I tried it on a single photos with dust spots and hit the “apply” button. A pop up with a progress bar came up and it said the estimated time was 10 seconds. I waited over 4 minutes and nothing happened. I have reasonable interconnect connection and most everything I do on the interest is fairly fast. What am I doing wrong?
Ken 24680
I also tried the new Landscape Mask and it also did not work at all. These AI tools are worthless on the desktop LR Classic.
Interestingly enough, the dust removal in ACR worked great on an image that LRc failed miserably on.
Athello9
Worked amazingly! Had a picture of an eagle flying, and the blue sky had several large dust specks.  LR identified and removed them perfectly.
Athello9
To clarify, it was on LRc, desktop.  Worked on several photos of a flying bird, bright blue background, with dust spots. I’d guess that’s about the easiest background for the tool to work on.
Opie Stark
Ended up just blurring my kid’s face and leaving the dust spot. Not a very useful tool
Ruona Photographer
Yes you have to manually remove every little speck but the program often replaces one speck of dust with another over and over again.
Ruona Photographer
the program replaces one speck of dust with another
Daniel Motta Photography
This does not work on bit.
PBR-DK
I think I found out why it does not work - the program doesn’t remove the dust by itself. You have to manually remove every little speck. The only thing the program does, is to activate the dust removal, so you can remove the dust specks with one click on each speck.
I must confess, that I thought that the program would scan the photo for dust and try to remove them automatically using AI - I don’t see why that should not be possible.
But I can see from some of the previous posts, that apparently the dust removal program does not support negative scans, which defeats the purpose of a dust removal program, to be honest !!
