vvivek4ever
Exposure Shift in Timelapse After Syncing Settings in Lightroom
  • July 6, 2024
  • 4 replies
  • 3280 views
Hi everyone,
I’ve been using Lightroom for over 10 years and specialize in timelapse photography. I’ve never faced this issue before, so I’m hoping someone can help.
I have a custom preset that includes basic settings, curves, color grading, and calibration settings. My usual workflow is to apply this preset to one image, make any necessary corrections, and then sync all settings across the entire sequence of photos. In the past, this method worked flawlessly, with no noticeable differences between images upon export.
However, for my last two timelapses, I’ve noticed a shift in exposure between many consecutive images. Initially, I thought this was due to changing light conditions that the camera couldn’t handle. But today, I’m certain it’s an issue with Lightroom’s sync function. I have two images with very similar camera settings and Lightroom edits, yet there’s a noticeable difference in exposure. Apart from changing colors in two far-away buildings, the camera settings and Lightroom edits are the same.
For a recent timelapse with 330 pictures, at least 35 images have this issue, resulting in flickering in the exported video. This is really frustrating.
I’ve attached screenshots of image 1 and image 2 along with their edited versions, along with the system info, for reference.
Any insights or solutions would be greatly appreciated. Thanks in advance!
[Moved from ‘Bugs’ to ‘Discussions’ by moderator, according to forum rules.]
Conrad_C
I was thinking of answering with a reply similar to richardplondon’s, and the only reason I didn’t post that earlier is because you’ve done a lot of time lapse photography, so I thought maybe you might already know about the issues with image-adaptive adjustments. But now that your testing seems to confirm that it does have to do with adaptive adjustments such as Shadows/Highlights, I agree that a solution is to do as much tone adjustment as possible using the Tone Curve, and if that isn’t enough, then add Shadows/Highlights and other Basic panel adjustments, but only as little as needed.
If this is the first time you’ve come across this issue, watching the video below is highly recommended, where the developer of LRTimelapse software goes into great detail about how to avoid exposure flickering induced by Lightroom Classic adaptive adjustments. The last part of the video, starting about 13 minutes in, is a revealing analysis of exactly which adjustments cause the most and least flickering when synced across many images. (From his article Stop Lightroom from adding Contrast Flicker to your Timelapses)
Also, note in the video that he demonstrates how some unwanted shifts may be made worse depending on whether a camera or Adobe raw profile is applied! This was new info to me.
vvivek4ever
Thank you for your insightful reply. Although I've been doing timelapse photography for a while, there's always something new to learn. This issue with adaptive adjustments and exposure flickering is entirely new to me, as I've never faced it before.
I typically edit with a combination of tone curve adjustments along with basic adjustments. However, not using highlights and shadows from the Basic panel is actually disrupting my workflow, and I'm unable to achieve the usual color and contrast I typically get with the combination.
I watched the LRTimelapse video you recommended and now understand how some adjustments can cause contrast flickering. I purchased LRTimelapse and am currently exploring different videos. It’s a nice tool.
Do you have any additional tips on how I can balance using both tone curve adjustments and minimal basic adjustments to maintain the color and contrast I'm aiming for?
Thanks again for your help!
Looking at the edited samples I do wonder if this could be arising from the nature and strength of adjustments used. Some Basic adjustments - shadows / highlights and clarity in particular - are more image-contrast-adaptive: meaning that for each image they are applied to, even when the slider is moved to the same value, a fresh assessment will be made for each image on how it should apply (a pixel of the identical starting value may receive a different adjustment within the two images, depending on what other tonalities it accidentally occurs in proximity to). The reality is that physical shutters are not perfectly repeatable from one operation to the next, so the absolute camera exposure may vary slightly even if everything is locked down on Manual. Also shot noise and to a lesser degree read noise is inherently variable shot to shot.
So very heavy use of a few strongly image-adaptive adjustments will tend to magnify any accidental variations between the original shots. More moderate use of these adjustments and the strategic combination of different adjustments will tend to do so much less, perhaps below the threshold of noticeability, all else being equal.
In my experience it's far better to (for example) combine a moderate general Contrast slider adjustment with moderate Shadows / Highlight adjustments, rather than (for example) trying to achieve everything just from setting extreme values for the Shadows / Highlights sliders.
Also, Tone Curve is not image-adaptive at all AFAIK, so this can act more as a neutral and constant tonal 'overlay'. Note highlights recovery for example, must be addressed properly in Basic panel adjustments: Tone Curve cannot optimise such things absolutely. It can only relatively darken or lighten whatever the Basic adjustments are producing.
vvivek4ever
Thank you for your detailed response. I think you're spot on with your analysis.
After reading your explanation, I decided to test your theory. I retained all the edit settings except for highlights and shadows, bringing both of these to 0. Surprisingly, the image looked almost the same as before.
Given this, I'm now looking for advice on how to best sync these settings across all images without introducing variability. Should I avoid using heavy adjustments for highlights and shadows altogether, or is there a better approach to achieve consistency?
Any tips on the strategic combination of different adjustments to maintain uniformity across the timelapse sequence would be greatly appreciated.
vvivek4ever
Attached images for your reference after bringing Shadows and Highlights down to 0.
johnrellis
I think the only effective way to narrow down the issue is to share the original two raws and the develop settings.  Select the first raw and do Metadata > Save Metadata To File. Then upload both raws and the .xmp sidecar for the first one (which contains the Develop settings) to Dropbox, Google Drive, or similar and include the sharing link here.
vvivek4ever
Thank you for the suggestion.
I wanted to mention that Richard's suggestion made a lot of sense. I retained all settings but set shadows and highlights to zero, and the images seem to match now. I am attaching the images for your reference
vvivek4ever
John, would you want RAW images and xmp to review?
johnrellis
"DirectX: NVIDIA GeForce GTX 1650 (31.0.15.4609)"
That driver is about seven months old. It's probably not causing your issue, but it's always good LR hygiene to be on the latest driver. Go to Nvidia.com and install the latest Studio driver.
vvivek4ever
Thank you for the suggestion. I'll definitely update to the latest Studio driver. It's good to rule out any potential contributing factors. I'll update the driver and see if it makes any difference.
