anothertal3
Issues importing certain MP4 videos - in need of help to determine the required format settings
  • November 3, 2017
  • 5544 views
Hey everyone,
I'm using the newest version of Lightroom Classic CC on Windows 10 (64 Bit).
Until recently I've been rendering videos using the now outdated version of Magix Video Deluxe 2013. Importing those to Lightroom (or playing them) is still working just fine.
However, I've switched over to a new version of that Magix VDL which provides a slightly different encoder and now It seems that I'm completely unable to export any AVC MP4 anymore that is being supported by Lightroom.
I can't see any previews during the import selection and when trying to process the files anyway I receive an error message reading "video does not contain video frames" (roughly translated from German version).
Important: The files in general are fine as they are playing flawlessly in VLC, Windows Media Player and can be read a whole lot of other tools.
Interestingly, when I re-encode the same file using Handbrake, the resulting file seems to work. But as encoding multiple times is certainly not an option, I'm trying to figure out which of those settings are making the big difference for Lightroom.
Below, I've attached the MediaInfo for an example file that cannot be imported ("VDL Cannot Import") and two Handbrake-processed files that seem to be working.
To be honest: I'm quite new to all those video formats and settings as I have simply been using the same preset again and again with the previous version of VDL. I've tried to fiddle around with the available export format settings (e.g. BASE or HIGH and format 3.1, 4, 5.1, etc) but to no avail.
I really hope that you can help me with this.
Many thanks in advance!
--- Unable to import ---
General
Complete name                            : F:\VDL Cannot Import.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/avc1)
File size                                : 574 MiB
Duration                                 : 6 min 37 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 12.1 Mb/s
Encoded date                             : UTC 2017-11-02 18:16:02
Tagged date                              : UTC 2017-11-02 18:16:02
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L3.2
Format settings                          : CABAC / 3 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 3 frames
Format settings, GOP                     : M=3, N=25
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate mode                            : Variable
Bit rate                                 : 12.0 Mb/s
Maximum bit rate                         : 16.0 Mb/s
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.519
Stream size                              : 567 MiB (99%)
Language                                 : English
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : mp4a-40-2
Bit rate                                 : 162 kb/s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 7.69 MiB (1%)
Language                                 : English
--- Can be imported ---
General
Complete name                            : F:\Can Import 1.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (isom/iso2/avc1/mp41)
File size                                : 248 MiB
Overall bit rate                         : 5 239 kb/s
Writing application                      : HandBrake 1.0.7 2017040900
Video
Format                                   : AVC
Format profile                           : Main@L3.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, RefFrames               : 4 frames
Codec ID                                 : avc1
Bit rate                                 : 5 076 kb/s
Height                                   : 720 pixels
Frame rate mode                          : Variable
Minimum frame rate                       : 12.500 FPS
Maximum frame rate                       : 25.000 FPS
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.220
Stream size                              : 240 MiB (97%)
Writing library                          : x264 core 148 r2708 86b7198
Encoding settings                        : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2017-11-02 21:13:41
Tagged date                              : UTC 2017-11-02 21:13:41
Audio
Format                                   : AAC
Format profile                           : LC
Bit rate                                 : 158 kb/s
Stream size                              : 7.47 MiB (3%)
Title                                    : Stereo / Stereo
Language                                 : English
Default                                  : Yes
Alternate group                          : 1
--- Also importable ---
General
Complete name                            : F:\Can Import 2.mp4
Format                                   : MPEG-4
File size                                : 219 MiB
Duration                                 : 4 min 9 s
Overall bit rate                         : 7 371 kb/s
Video
Format                                   : AVC
Format profile                           : High@L3.1
Format settings                          : CABAC / 5 Ref Frames
Format settings, RefFrames               : 5 frames
Codec ID                                 : avc1
Bit rate                                 : 7 208 kb/s
Height                                   : 720 pixels
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.313
Stream size                              : 215 MiB (98%)
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2017-11-02 23:16:58
Tagged date                              : UTC 2017-11-02 23:16:58
Audio
Format                                   : AAC
Format profile                           : LC
Bit rate                                 : 156 kb/s
Stream size                              : 4.66 MiB (2%)
Default                                  : Yes
Alternate group                          : 1
Correct answer anothertal3
Ok, I've found a workaround for what I start to believe might be a Lightroom bug.
The issue seems to be related to the Codec ID ("brand") that is written by the used encoder. My previous Magix version used a MediaConcept encoder which wrote "mp42". That worked fine.
Handbrake uses the x264-encoder (I think) which writes "mp42" and works as well.
The new Magix uses an Intel Encoder which writes "isom" as tag. According to some web recherches, this is valid. Apparently, only Lightroom seems to be unable to cope with it. Other media player and tools do just fine.
Similar problems have been described here: ISOM Codec and PPro CC , although no final solution was found.
My current workaround:
  1. Create media file
  2. Use mp4box [1] and the command "mp4box -brand mp42 [filename]" to change the Codec ID without reencoding the whole file
  3. Profit. It works immediately.
If Lightroom just supported this encoding, everyone would be happy
[1] MP4Box | GPAC
anothertal3
anothertal3AuthorCorrect answer
[1] MP4Box | GPAC
