Sep 18, 2026 5:54 PM UTC
Lightroom Classic 15.5.1 disables Intel Arc 140V GPU, while Camera Raw 18.6 on same machine reports full acceleration same machine detects the same GPU and reports full acceleration.
Problem summary:
Lightroom Classic 15.5.1 consistently disables GPU acceleration on my HP OmniBook Ultra Flip with Intel Arc 140V graphics, even though Photoshop / Adobe Camera Raw 18.6 on the exact same machine detects the same GPU and reports full acceleration.
This causes Lightroom Classic AI Denoise / Super Resolution to fall back heavily to CPU and run dramatically slower.
System:
  • HP OmniBook Ultra Flip
  • Intel Core Ultra 9 288V
  • Intel Arc 140V GPU
  • 32 GB RAM
  • Windows 11 Home
  • Windows build: 11.0.26200
  • Intel graphics driver tested:
    • 32.0.101.8974
    • 32.0.101.8993
    • 32.0.101.9030
  • Current driver: 32.0.101.9030
Lightroom Classic:
  • Lightroom Classic 15.5.1
  • Internal Camera Raw: 18.5.1 [2687]
Lightroom Classic System Info reports:
Graphics Processor Info:
Init State: GPU disconnected
User Preference: Auto
GPU for Preview Generation: Off
GL_RENDERER: Intel(R) Arc(TM) 140V GPU (16GB)
GL_VERSION: 4.6.0 - Build 32.0.101.9030
GPUDeviceEnabled: false
OGLEnabled: true
Lightroom also reports:
Dedicated GPU memory used by Lightroom: 0.0MB / 0.0MB (0%)
The GPU is clearly detected, but Lightroom Classic disables it.
Control test in Adobe Camera Raw:
On the exact same machine:
  • Photoshop / Adobe Camera Raw version: 18.6
  • Same Intel Arc 140V GPU
  • Same 32.0.101.9030 Intel driver
Camera Raw Preferences → Performance reports:
Your system automatically supports full acceleration.
AI Denoise on the same Sony ARW files completes in approximately 20 seconds in Camera Raw.
On another laptop with an NVIDIA RTX 4060, Lightroom Classic performs AI Denoise on the same class of RAW files in under approximately 15 seconds and correctly registers GPU usage.
This strongly suggests the issue is not the RAW files, catalog, Windows installation, or Adobe AI Denoise itself.
Troubleshooting already completed:
  • Updated Lightroom Classic to latest available version
  • Completely uninstalled and reinstalled Lightroom Classic
  • Tested Lightroom Classic 15.4.1, 15.5, and 15.5.1
  • Tested Intel drivers 8974, 8993, and 9030
  • Used DDU in Safe Mode for a full Intel graphics-driver cleanup
  • Reinstalled Intel Arc graphics driver cleanly
  • Deleted/rebuilt Camera Raw GPU configuration files
  • Checked for TempDisableGPU2 / TempDisableGPU3 files — none present
  • Forced Lightroom to High Performance GPU in Windows Graphics settings
  • Checked Device Manager for additional/virtual display adapters
  • Only Intel Arc 140V appears under Display adapters
  • Checked for third-party indirect/virtual display drivers — none found
  • Tested regular Lightroom desktop app — GPU acceleration also disabled there
  • Moved Lightroom Classic catalog out of OneDrive to a local path
  • Rebuilt damaged local sync database
  • Confirmed Photoshop itself recognizes and enables the Arc 140V
  • Confirmed Camera Raw 18.6 recognizes and fully accelerates the Arc 140V
Current Lightroom catalog path:
C:\Users\miker\Lightroom Catalog\Lightroom Catalog.lrcat
Expected behavior:
Lightroom Classic should recognize and enable the Intel Arc 140V GPU, consistent with Adobe Camera Raw 18.6 on the same system.
Actual behavior:
Lightroom Classic detects the Arc 140V but reports:
and AI tasks fall back to CPU.
Most important comparison:
Same machine, same GPU, same graphics driver:
Adobe Camera Raw 18.6:
Full GPU acceleration
Denoise ~20 seconds
Lightroom Classic 15.5.1 / Internal Camera Raw 18.5.1:
GPU disconnected
Denoise dramatically slower
Request:
Please investigate whether Lightroom Classic 15.5.1 / internal Camera Raw 18.5.1 has an Intel Arc 140V GPU initialization or compatibility issue that is resolved in Camera Raw 18.6.
I can provide full Lightroom Classic System Info, GPU logs, screenshots, or additional diagnostic files if needed.
    Anshul_Saini
    Sep 18, 2026 11:46 PM UTC
    Hi @michaelr56512575,
    Thank you for the exceptionally detailed report and for testing this across multiple Lightroom Classic and Intel driver versions. The comparison with Camera Raw 18.6 on the same machine, GPU, and driver is particularly useful.
    Since you’ve already worked through driver cleanup, GPU configuration, preferences, reinstalling Lightroom Classic, and catalog/location tests, I don’t want to send you through the same troubleshooting again.
    Could you please provide these two items so we can investigate the exact configuration further?
    1. A full-resolution screenshot of Lightroom Classic > Preferences > Performance, showing the GPU status/message.
    2. Help > System Info > Copy, pasted here in full.
    Also, can you confirm whether the Camera Raw 18.6 test was performed through Photoshop’s Camera Raw plugin, and whether the same Sony ARW file was used for the comparison?
    One additional comparison may also be useful. A couple of users with Intel Arc systems have reported different results with the Intel Arc Pro driver. If that driver is supported for your system, could you test it with Lightroom Classic and let us know whether the GPU status changes from “GPU disconnected” and whether Denoise uses the GPU? Please note the exact Intel driver version used for the test so we can compare the results.
    Your comparison between the standalone Camera Raw 18.6 and the Camera Raw 18.5.1 integrated with Lightroom Classic is particularly useful. Lightroom Classic receives its own integrated Camera Raw updates, so we’re interested in seeing whether a newer Lightroom Classic build changes the GPU detection behavior.
    Thanks again for providing such a thorough set of comparisons.
    Best,
    Anshul Saini
    Sep 21, 2026 3:20 PM UTC
    The Camera Raw 18.6 test was performed through Photoshop’s Camera Raw Plugin and I used the same Sony ARW file for testing (tested multiple ARW files). I also attempted a test in Bridge (attached image settings of Bridge) and it failed as well.
    Here is the system info from Light Room Classic.
    Lightroom Classic version: 15.5.1 [ 202608131348-cab7eed5 ]
    License: Creative Cloud
    Language setting: en
    Operating system: Windows 11 - Home Premium Edition
    Version: 11.0.26200
    Application architecture: x64
    System architecture: x64
    Logical processor count: 8
    Processor speed: 3.3GHz
    SqLite Version: 3.36.0
    Adobe GSDK Version: 1.4.0.213
    CPU Utilisation: 8.0%
    Power Source: Plugged In, 94%  (Charging)
    Built-in memory: 32239.5 MB
    Real memory available to Lightroom: 32239.5 MB
    Real memory used by Lightroom: 1693.5 MB (5.2%)
    Virtual memory used by Lightroom: 1752.9 MB
    GDI objects count: 772
    USER objects count: 2505
    Process handles count: 2535
    Memory cache size: 943.0MB
    Internal Camera Raw version: 18.5.1 [ 2687 ]
    Maximum thread count used by Camera Raw: 5
    Camera Raw SIMD optimization: SSE2,AVX,AVX2
    Camera Raw virtual memory: 108MB / 16119MB (0%)
    Camera Raw real memory: 153MB / 32239MB (0%)
    Cache1:
    NT- RAM:0.0MB, VRAM:0.0MB, Combined:0.0MB
    Cache2:
    m:943.0MB, n:0.0MB
    U-main: 94.0MB
    System DPI setting: 144 DPI (high DPI mode)
    Desktop composition enabled: Yes
    Standard Preview Size: 2880 pixels
    Displays: 1) 2880x1800
    Input types: Multitouch: Yes, Integrated touch: Yes, Integrated pen: Yes, External touch: No, External pen: No, Keyboard: Yes
    Enable HDR in Library: OFF
    GPU for Preview Generation: Off (S6_0)
    Application folder: C:\Program Files\Adobe\Adobe Lightroom Classic
    Library Path: C:\Users\miker\Lightroom Catalog\Lightroom Catalog.lrcat
    Settings Folder: C:\Users\miker\AppData\Roaming\Adobe\Lightroom
    Installed Plugins:
    1) AdobeStock
    2) Flickr
    Config.lua flags:
    Adapter #1: Vendor : 8086
        Device : 64a0
        Subsystem : 8cde103c
        Revision : 4
        Video Memory : 128
    Adapter #2: Vendor : 8086
        Device : 64a0
        Revision : 4
        Video Memory : 80
    Adapter #3: Vendor : 1414
        Device : 8c
        Subsystem : 0
        Revision : 0
        Video Memory : 0
    AudioDeviceIOBlockSize: 1024
    AudioDeviceName: System Default - Speaker (Realtek(R) Audio)
    AudioDeviceNumberOfChannels: 2
    AudioDeviceSampleRate: 48000
    Build: LR5x31
    Direct2DEnabled: false
    GL_ACCUM_ALPHA_BITS: 16
    GL_ACCUM_BLUE_BITS: 16
    GL_ACCUM_GREEN_BITS: 16
    GL_ACCUM_RED_BITS: 16
    GL_ALPHA_BITS: 8
    GL_BLUE_BITS: 8
    GL_DEPTH_BITS: 24
    GL_GREEN_BITS: 8
    GL_MAX_3D_TEXTURE_SIZE: 2048
    GL_MAX_TEXTURE_SIZE: 16384
    GL_MAX_TEXTURE_UNITS: 8
    GL_MAX_VIEWPORT_DIMS: 16384,16384
    GL_RED_BITS: 8
    GL_SHADING_LANGUAGE_VERSION: 4.60 - Build 32.0.101.9030
    GL_STENCIL_BITS: 8
    GL_VENDOR: Intel
    OGLEnabled: true
    GL_EXTENSIONS: GL_AMD_depth_clamp_separate GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_cl_event GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_robustness_isolation GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_meminfo GL_ATI_separate_stencil GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_polygon_offset_clamp GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_semaphore GL_EXT_semaphore_win32 GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_s3tc GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_IBM_texture_mirrored_repeat GL_INTEL_conservative_rasterization GL_INTEL_fragment_shader_ordering GL_INTEL_framebuffer_CMAA GL_INTEL_map_texture GL_INTEL_multi_rate_fragment_shader GL_INTEL_performance_query GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_shader_subgroup GL_KHR_shader_subgroup_arithmetic GL_KHR_shader_subgroup_ballot GL_KHR_shader_subgroup_basic GL_KHR_shader_subgroup_clustered GL_KHR_shader_subgroup_quad GL_KHR_shader_subgroup_shuffle GL_KHR_shader_subgroup_shuffle_relative GL_KHR_shader_subgroup_vote GL_NV_blend_square GL_NV_conditional_render GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_timeline_semaphore GL_OVR_multiview GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
    Anshul_Saini
    Oct 19, 2026 7:10 PM UTC
    Apologies for the delayed follow-up, especially after you took the time to provide such detailed information, screenshots, and test results.
    When you have a chance, could you please update to Lightroom Classic 15.6 and Camera Raw 18.7 and check the GPU status again?
    Once done, let me know what you see under Preferences > Performance in Lightroom Classic and Camera Raw through Photoshop. If convenient, please check Camera Raw through Bridge as well, since your previous test showed different behavior there.
    If Lightroom Classic still reports “GPU disconnected” or “Graphics acceleration is disabled due to an error,” please also paste a fresh Help > System Info from Lightroom Classic and try the following steps:
    1. Try deleting the file "Camera Raw GPU Config.txt" as detailed here:
    https://helpx.adobe.com/lightroom-classic/desktop/technical-support/technical-issues/gpu-issues/troubleshoot-gpu.html#solution-3
    That will prompt LR to reevaluate your GPU's capabilities.
    2. Then delete any TempDisableGPU2 and TempDisableGPU3 files:
    https://helpx.adobe.com/camera-raw/desktop/troubleshoot/acr-gpu-faq.html#troubleshoot-acr
    3. After doing that, restart LR. Then go to Preferences > Performance to verify that Use Graphics Processor is set to Auto.
    If that doesn’t help, could you please collect the log from Lightroom Classic using these steps?
    1. Launch the app, go to preferences to check GPU status and then quit the app.
    2. Press Windows + R, enter:
      %APPDATA%\Adobe\CameraRaw\Logs
    3. Please attach the log files generated from that session here.
    If the issue still reproduces in the latest versions, I’ll forward the updated results and the logs to the team.
    Thanks again for your patience and for all the work you’ve already put into documenting this.
    Best,
    Anshul Saini
