Lightroom Classic CC - white balance doesn't match camera settings
I set a custom white balance in camera (using kelvin settings) to 5600, but LR develop module shows it as 6000. I'm using a Nikon D810, shooting RAW, of course. This happens whether I import as NEF or DNG. When I set the camera to "Flash" mode for white balance, LR says I used 7100K. The camera manual says "Flash" is 5400K. One of my colleagues, who also shoots with a Nikon D810, sees exactly the same results.
Is this a problem with Lightroom? With all Nikon D810s? Is there a setting I'm missing? I need to submit RAW files for a certification I'm applying for, and they need to verify the WB setting in the files (as shot). I'm concerned that they'll see the wrong values if they use LR to read the data. Beyond that, I'm concerned that my images are ending up too cool because of this issue. Sure, I can adjust the WB to taste for client images, but would much prefer to be able to rely on the specific temperature values.
Has anyone else noticed this? Is it a bug? Is there a better way to inspect the RAW files to see what settings were actually used?
Thanks!
-- Alejandro
