ians86193080
lightroom will not read sony ARW files
  • March 26, 2015
  • 13 replies
  • 235385 views
I understood the latest version of Lightroom supported the recent Sony A7 series, whose RAW files are Sony's own ARW files. I have the latest Lightroom but it will not read these files.
    Correct answer JP Hess
    Here is a list of the Sony A7 series cameras that Lightroom supports, and the version of Lightroom required. The Lightroom versions are in the highlighted area.
    If you are certain you have the appropriate version of Lightroom installed, then provide more information. Can your operating system browser see the raw files? Have they been downloaded to your hard drive? What operating system are you using? What is the exact version of Lightroom?
    ericd87384758
    Is there a release date for the newer version of Lightroom that will support the newer ARW files? I have the same problem with Sony Alpha 7 II.
    Have you tried the update that came out today?
    martinw24967940
    Yes. Still not working for my A7ii arw files
    I have lightroom CC and am trying to import arw files from a sony a6300.  Its not recognizing the format of the files.  I am running the latest mac OS El Capitan.
    I did have an older version of lightroom however that was fully removed.  The files are brand new so its nothing to do with cache of the thumbnails.
    Any help would be appreciated.
    dj_paige
    What does it mean when you say "not recognizing"? What happens? What do you see? What is the exact unedited word-for-word error message? Give us the details.
    "some import operations were not performed"  "the files cannot be opened by lightroom." - this is followed by a list of arw files that were not imported
    Thanks for your help!
    JP Hess
    JP HessCorrect answer
    viktors82497016
    SONY ILCE 7S II (ARW) Lightroom support ???
    dcarnielli  wrote
    I have Lightroom 7.1 and still not importing arw files. Any fix?
    Same here and I'm using A7R III...
    You need 7.1 or 7.2 to read A7Riii files. Are you on that version for sure? Check the help menu -> System Info
