ians86193080
lightroom will not read sony ARW files
  • March 26, 2015
  • 13 replies
  • 235298 views
I understood the latest version of Lightroom supported the recent Sony A7 series, whose RAW files are Sony's own ARW files. I have the latest Lightroom but it will not read these files.
    Correct answer JP Hess
    Here is a list of the Sony A7 series cameras that Lightroom supports, and the version of Lightroom required. The Lightroom versions are in the highlighted area.
    If you are certain you have the appropriate version of Lightroom installed, then provide more information. Can your operating system browser see the raw files? Have they been downloaded to your hard drive? What operating system are you using? What is the exact version of Lightroom?
    RPMartinez
    Latest PS and LR cannot open the latest Sony ARW Lossless Uncmpressed Files of mt A7iv
    JP Hess
    The A7R IV Has been supported since version 8.4.1 And Lightroom (the cloud version) since 2.4.1.
    wesleys47818336
    This is crazy. I also just purchased ther new Sony A9ii and can't get the photos into Lightroom or Photoshop. Come on Adobe. Get an update out.
    For now I'm using https://rawtherapee.com/ before update.
    Sony A7 IV user...
    Gents,
    I am on Release 7.1 and Camera Raw 10.1 ... but unable to read a6000 ARW files.
    Am I doing something wrong ?
    Just Shoot Me
    What is the exact error message you are getting and or what exactly do you see or don't see on the screen when trying to import.
    We need specifics. Also a screen shot will help.
    Yes sure, pls see below ... I do not get any error message, the image is not displayed in Develop mode.
    I have the same problem with RAW files from my a7 and an older version of LR that has worked perfectly well with RAW files from my a850. I expect that Adobe in its benevolence has issued a free patch to address the issue and is not using the same extortionate technique employed by the video playback software companies of periodically disabling their software to force an upgrade when they want more money. Can someone tell me where I can dowmload the patch?
    F. McLion
    Which 'same' problem?
    What is your exact version of LR and which exact camera do you try to import RAW from?
    --- Got your issue resolved? Please label the response as 'Correct Answer' to help your fellow community members find a solution to similar problems. ---
    robbertf47248719
    I downloaded a test version of the Lightroom and it functions with my A7ii
    Now i bought a version in the store lightroom 6 and i all my Sony files are not working. Is it now really that i bought it for nothing?
    Thanks for the help
    Robbert Fielemon
    JP Hess
    If what you have is the Sony A7RII and you just installed Lightroom 6, you only have Lightroom 6.0. You need at least Lightroom 6.1.1 but Lightroom has progressed to Lightroom 6.10.1 at this point. You need to update in order to have support for your camera.
    There is a nasty bug in the 2015.12 updater that manifests itself on some
    machines. I have seen it on a few machines of people I teach Lightroom now.
    It will install the update but will actually revert the installed version
    of Lightroom to 2015.0. The only solution that always works is to
    completely wipe creative cloud and Lightroom from your machine using
    creative cloud cleaner from Adobe:
    https://helpx.adobe.com/creative-cloud/kb/cc-cleaner-tool-installation-problems.html
    and then reinstall creative cloud from Adobe and install Lightroom from
    there. This will get you to 2015.12. Nothing else seems to work if you
    have this problem. Not just wiping Lightroom and reinstalling. Not manually
    downloading the updater. It just reverts Lightroom to 2015.0.
    On Mon, Aug 28, 2017 at 11:14 AM, alecr75723364 <forums_noreply@adobe.com>
    Hi all,
    I recently got the Sony A7III camera and started taking photos in RAW. I previously used the Canon with the .CR2 extension with no problem. However, the .ARW extension is not being recognized by Lightroom. I have Lightroom 6.0. It IS a registered product, but when I try to go to update it (even though I thought that Lightroom 5.7 and higher would read these), it will only let me buy Lightroom CC and NOT let me update my product.
    mekilie
    This is incorrect.  I have Lightroom 10.12 [4] and my .ARW files shot on my Sony A7xII will not import into Lightroom.
    KR Seals
    10.12 is not a Lightroom  version number. That looks like a MacOS version number.
    In Lightroom, go to Help/About Photoshop Lightroom (the bottom selection in the drop down menu and you will see something like this:
    The number on the left is the LR version number. If you are using LR 6 and not CC, the first number will be "6"
    Ken Seals - Nikon Z 9, Z 8, 14mm-800mm. Computer Win 11 Pro, I7-14700K, 64GB, RTX3070TI. Travel machine: 2021 MacBook Pro M1 MAX 64GB. All Adobe apps.
    I'm having the same problems with A6300 ARW files. I just got lightroom yesterday. Only imports the jpegs. But I just want the ARW files. Looked around and thought I downloaded The Camera Raw Installer but that didn't work either. I'm lost on what to do next. I got this to edit Raw files and not jpeg. I have lightroom on my phone for jpegs. If anyone has solved this problem please help. I'm running LR on windows 10. Thanks
    JP Hess
    If you just got Lightroom 6 yesterday, you probably installed Lightroom 6 .0. You've got to upgrade to Lightroom 6 .5 or later in order to have support for your camera.  I don't know Why you are trying to download the Camera Raw installer because it won't have any effect on Lightroom. All of that technology is part of the Lightroom program. You have to update the Lightroom program which is currently out Lightroom 6.9. If you update the program then you will have support for your camera. Trying to update Lightroom with the camera raw plug-in will have no effect on Lightroom at all.
    Ok. I didn't know if the camera raw had anything to do with it. That was a shot in the dark because I got desperate. I will see if I can find the update because of late I've been unlucky. I went through the Lightroom's interface itself to have it manually check for updates. Then I went through creative cloud to which told me I was updated as far as possible. I didn't get the creative cloud version though. I had to search deep to find the non subscription Lightroom. I'm now in the process in checking to see f the camera drives are all updates and downloaded to my computer. I'll try t look for the 6.9 because from what my version is telling me is that I have 6.0. Which I'm questioning the truth in that because its telling me I have downgraded from Windows 10 to 8. Thanks for your help.
    This is the info I get regarding the version:
    Lightroom version: 6.0 [1014445]
    License: Perpetual
    Operating system: Windows 8.1 Home Premium Edition
    Version: 6.3 [9600]
    Application architecture: x64
    System architecture: x64
    I'm on LR 6.5.1 on a Mac El Capitan 10.11.5 and it reads and is able to import Sony's ARW files.
    Cheers.
    Hi all,
    I just downloaded a free trial of Creative Cloud in order to just check it out and purchase the software.
    I took some photos today on my Sony RX100IV in both JPEG and ARW format. I tried to import them into Lightroom but only the JPEGs will populate.
    I was using a 32BIT computer so maybe that has something to do with it.
    But I tried to convert to DNG but no luck.
    Why can't I import RAW files for editing? Am I doing something wrong?
    If not, what can I do?
    I am using Lightroom 5.7.1 on a Windows 10 32 bit laptop.
    The Sony RX 100 IV was first supported in LR 6.1.1. Lightroom 5.7.1 can't read it. Unfortunately LR 6 can only run on 64 bit machines, so your laptop will not work. You should be able to read the files in 5.7 after you convert to dng using Adobe's dng converter though so I am curious why that didn't work. Can you post one of the dng files, perhaps through a dropbox link?
    I have the same problem. I am unable to open AWR files in Lightroom even though I just did the update. I have a Sony A7ii camera with the latest firmware. First I get a message when in Import screen that says "Not a able to preview file" and then when I import the files to the catalogue I get an error that says "Files not recognize" or something like that. Not sure what the issue is and hopefully someone can help me.
    Thanks.
    rlopez, this means you are not running a new enough Lightroom version. Check which version you are running either in the splash screen when you open it or by doing a system info from the help menu. It should be at least 6.1.1 (or CC 2015.1.1) to open A7rII files. Lightroom 6/CC2015 updates are done from the creative cloud app, not the update item in the help menu (indeed very confusing!). If you are still on Lightroom 5 and you are loading A7II, it should be 5.7.1 (not 5.7!). Lightroom 5 will not load A7rII files at all except if you transcode them to dng files first. the 5.7.1 update does not download automatically from the update menu for some unknown reason, but has to be downloaded directly from Adobe.
    I too am having this problem. Hard to believe adobe cant handle this better. Anyway, I think I need to update from Creative CLoud, which is interesting but I have no idea what that is.  Any link? or?
    thanks
    License: Perpetual
    Operating system: Windows 8.1 Business Edition
    Version: 6.3 [9600]
    Logical processor count: 4
    Processor speed: 2.4 GHz
    Built-in memory: 8097.0 MB
    Real memory available to Lightroom: 8097.0 MB
    Real memory used by Lightroom: 271.5 MB (3.3%)
    Virtual memory used by Lightroom: 217.3 MB
    Memory cache size: 0.0 MB
    Maximum thread count used by Camera Raw: 2
    Camera Raw SIMD optimization: SSE2,AVX,AVX2
    System DPI setting: 144 DPI (high DPI mode)
    Desktop composition enabled: Yes
    Displays: 1) 1920x1200
    Input types: Multitouch: Yes, Integrated touch: Yes, Integrated pen: Yes, External touch: No, External pen: No, Keyboard: Yes
    Graphics Processor Info:
    Intel(R) HD Graphics 4400
    Check OpenGL support: Passed
    Vendor: Intel
    Version: 3.3.0 - Build 20.19.15.4331
    Renderer: Intel(R) HD Graphics 4400
    LanguageVersion: 3.30 - Build 20.19.15.4331
    Application folder: C:\Program Files\Adobe\Adobe Lightroom
    Library Path: C:\Users\tsackett\Pictures\Lightroom\Lightroom Catalog.lrcat
    Settings Folder: C:\Users\tsackett\AppData\Roaming\Adobe\Lightroom
    Installed Plugins:
    1) Behance
    2) Canon Tether Plugin
    3) Facebook
    4) Flickr
    5) Leica Tether Plugin
    6) Nikon Tether Plugin
    Config.lua flags: None
    Adapter #1: Vendor : 8086
      Device : a16
      Subsystem : 51414
      Revision : b
      Video Memory : 112
    Adapter #2: Vendor : 1414
      Device : 8c
      Subsystem : 0
      Revision : 0
      Video Memory : 0
    AudioDeviceIOBlockSize: 1024
    AudioDeviceName: Speakers (Realtek High Definition Audio)
    AudioDeviceNumberOfChannels: 2
    AudioDeviceSampleRate: 44100
    Build: Uninitialized
    Direct2DEnabled: false
    GPUDevice: not available
    OGLEnabled: true
    ericd87384758
    Hi all,
    Seems I was a bit naive in terms of understanding Lightroom's update feature. I has assumed that, being on 5.7, when I check for updates and see I am up to date, I would be on 5.7.1. Not true after looking slightly deeper (which admittedly I should have done originally).
    I was able to import RAW files from my Alpha 7 II by first going to the Adobe site and forcing the upgrade to 5.7.1. I also went to the Sony site and upgraded camera body firmware to 3.10
    I don't see anywhere to selected 'uncompressed raw' so I have to assume that RAW format is now uncompressed by default. Would this be true?
    Everything is working perfectly now ..... thanks for your help. Love this community,
    Eric
    Eric, the option for uncompressed raw on your A7II is shown here: http://briansmith.com/sony-a7ii-firmware-update-fw-2-00-adds-pdaf-uncompressed-raw/ You won't be able to read those files in LR 5.7.1 directly unfortunately. You can read them by first converting the files to dng using the latest dng converter which is a free download from Adobe.
