phototocanvaspdx
Print driver issues with Lightroom and PS in Sonoma
  • November 18, 2023
  • 822 views
I own a print shop and print with LR and PS all day long to Canon large format printers. Since Sonoma not only are my presets pretty much worthless but I have limited options in the drivers. If using LR to print, and I select the paper profile in LR when I click Printer.... color matching is grayed out. Seems half the time its set to Canon Color Matching and half the time to Colorsync. If its set to Canon Color matching i have to go back to LR and change it to "managed by printer" in order to select the proper profile within the driver. Anyone know whats going on here?
JohanElzenga
Sounds like you may be using the limited Apple AirPrint drivers for your printer rather than the driver from the manufacturer.
-- Johan W. Elzenga
phototocanvaspdx
Thats not the case. I print for a living i make sure not to use those. It keeps bouncing back and forth on its own.
phototocanvaspdx
There have been many threads, not just in LrC, about this issue with printing in LrC since Ventura and it continued into Sonoma.  LrC 13 print works correctly in Monterey.  Apple appears to have messed this up in Ventura and is not fixing it.
Have you had this issue in any other apps beside Adobe apps? The issue doesnt happen in Apples preview app which is why im assuming they havent fixed it.
