Problem Importing Photos into Lightroom Classic
I am trying to import phots from my camera into lightroom classic but keep getting a message saying either:
- “could not copy a file to the destination folder because it is not writable”
or
I am using a MacBook Pro with macOS Sequoia version 15.7.4
I am using Adobe Lightroom Classic Release 15.2
Destination Drive is an external Hard Drive which has all my Library Photos
Catalog is in the “Lightroom” folder inside the “Pictures” folder on my Mac
I have already checked/done the following with no result:
- The destination drive is not full and has sufficient space still available for the photos being imported
- The folder into which I am trying to import the file has read and write permission in mac os
- Adobe Lightroom Classic has “Full Disk Access” under mac OS Settings/Privacy & Security Settings
- I have tried “Clear Recent Paths” in the Destination Folder
- I have tried unticking “Make a Second Copy To : ” in the File Handling section and then importing
- I have tried ticking “Make a Second Copy To : ” in the File Handling section and the creating a different location for the second copy
- I have tried ticking and unticking “Into Subfolder”
The following image shows the Destination panel, currently with the “Into Subfolder” option unchecked. As can be seen (please see section at the bottom of the image circled in red) the folders in the year and date format for the photos being imported are being shown within the selected destination folder on my external hard drive and are ticked and also correctly reflect the number of images to be imported.
I am starting to go insane as I think I have followed all suggested fixes that I have found online. I also have the exact same problem and error message when trying to import photos into the destination folder from my iPhone as well or from an SD card using my SD card slot on my Mac.
I am probably making a silly mistake or missing an obvious step or setting but I just can’t work it out. Therefore any help will be much appreciated. Thank you
