shawnh97010311
SDK Question - Match Total Exposure
  • April 15, 2022
  • 2937 views
Hey all!
Looking for a little insight into the SDK regarding Match Total Exposure. Anyone know of a way to utilize Match Total Exposure within the SDK? Specifically for replicating the Match Total Exposure effect on a set by set basis automatically. Thanks for the insight.
johnrellis
Match Total Exposures adjusts the target photo's Exposure develop setting so that its effective exposure value is the same as that of the source photo.  Below is the code my Any Filter plugin uses for computing exposure value (EV) and effective exposure value.  You can get the shutter speed, aperture, and ISO using photo:getRawMetadata().
public number
ev (number shutterSpeed, number aperture, number iso)
Returns the exposure value of the shutterSpeed, aperture, and iso, or nil
if any one of them is nil.
function ExposureValue.ev (es, shutterSpeed, aperture, iso)
    return (shutterSpeed and aperture and iso) and
        log2 (aperture ^ 2 / shutterSpeed) - log2 (iso / 100) or nil
    end
public number
effectiveEV (number shutterSpeed, number aperture, number iso,
    string processVersion, number exposure2012, number exposure)
Returns the effective exposure value, taking into account the additional
stops of the Develop setting "exposure2012" (if "processVersion" is "6.7")
or "exposure" (if "processVersion" is earlier).  Returns nil if any of the
arguments actually used to compute effective EV are nil.
function ExposureValue.effectiveEV (es, shutterSpeed, aperture, iso,
        processVersion, exposure2012, exposure)
    local processVersionNum = tonumber (processVersion) or 0
    local exp = processVersionNum >= 6.7 and exposure2012 or exposure
    return (shutterSpeed and aperture and iso and exp) and
        ExposureValue.ev (es, shutterSpeed, aperture, iso) - exp or nil
    end
shawnh97010311
John,
Thank you again for your help. And just for my clarity, is this code affective for locating exposure for each photo in a set of images to ultimatley match the visual exposure of an 'anchor' image? I just want to make sure we are on the same page with the intended outcome. You've been a huge help. Thank you!
johnrellis
John,
Thank you. One more question while I have you. Do you have any similar code within your plugin that deals with matching WB or temp/tint effectively? I know it's a whole other animal but you seem to have the right approach. Appreciate any suggestions you have on matching temp/tint to a reference image for a set of images.
I know very little about setting white balance algorithmically, other than that you can set Temperature/Tint via photo:applyDevelopSettings() (just as you can with Exposure2012).  From the little I've read here and other places, the very concept of "temperature" is squishy, in that for any given temperature, there is a broad range of "white" colors that are all deemed to have the same temperature; and cameras and software apps don't use the same algorithm for measuring temperature.
