mb43188522
Oct 6, 2026 4:42 PM UTC
SELECT SKY MASK selects parts of architecture and vegitation
I use LRc to edit B7W photos.  When using Select Sky mask LRc invariably selects parts of buildings and begitation that border the sky. I can remove these with the Subtract option for the mask, but it is an extra workflow step that I would like to avoid.  Is there any fix that Adobe is planning?
    dj_paige
    Oct 8, 2026 9:47 AM UTC
    I don’t believe there is a perfect sky mask. There are many videos on YouTube with methods that might work better than the built in sky mask, but even those are not perfect (example of one of the better methods, but as I said it is better but still not perfect). Right now, if you want a really good sky mask, you will have to do adjustments using subtraction or the new feather and edge sliders.
    Oct 8, 2026 5:49 AM UTC
    I’ve check and see the same. With such complex masking, automated processes will inevitably reach their limits, making manual touch-ups necessary. I believe the accuracy of AI-generated sky masks will continue to improve in future versions; however, for skies with many irregularities, manual refinement will still be required.
    Do you have try to improve the selection with the new feather and edge controls?
    My System: Intel i7-8700K - 64GB RAM - NVidia Geforce RTX 3060 - Windows 11 Pro 26H2 -- LR-Classic 16 - Photoshop 28 - Nik Collection 9 - PureRAW 6 - Topaz Photo AI
    mb43188522
    Oct 7, 2026 9:56 PM UTC
    Attached unedited an Sky Mask. I am tired of doing subtractions!
    Oct 6, 2026 4:52 PM UTC
    Does this happen only on one image or more (many) images are affected?
    How contrasty are the images? It’s possible that the sky couldn’t be identify correctly on low-contrast.
    If it’s possible show us a screenshot of the appropriate image.
