Importing RAW to iPad Pro and CC & Using Lightroom Classic
I havne't been able to find the answer to this workflow question so thought I'd ask here.
First off, I generally do all my work in Lightroom Classic. I do however do edits now and then on my iPad Pro to those(Smart Previews) that I have synced from Lightroom Classic. This works fine.
I understand that if I do want to use RAW files in Lightroom CC and already have the smart previews synced from Classic - I can drag the RAW files into CC and Lightroom will recognize the smart previews are already there in the catalog and just simply switch the smart previews to RAW rather than add a duplicate photo. With this being said, can the opposite be done? If I have RAW files I added to CC from my iPad can I simply import the same RAW files on my desktop Classic client and have the edits I made on my iPad Pro pull down into classic on the imported raw files? I know this is confusing, let me try and explain further.
If I am traveling and I import the RAW files from my SD card into Lightroom on my iPad Pro, I know this sends the entire RAW file to the cloud. Now when I get to my desktop and open up Classic I understand it will pull these RAW files down to the folder I have set in preferences. The problem here is with 80MB raw files and uploading 100 RAW files to the cloud and then to be pulled down into Classic is a bit silly. I want to be able to import RAW into my iPad and then made edits. Then when I get to my desktop import my RAW files again from my SD card and have CC and Classic know these files are the same and not pull down the RAW from the cloud, but pull the edits down.
