huhan0423
Lightroom 9.3 does not recognize or enable GPU acceleration on a system with Intel Core Ultra X7 and Arc Xe2 iGPU
  • March 7, 2026
  • 79 views
My newly purchased laptop features with intel’s new CORE ULTRA X7 358H, Arc B390 iGPU. Lightroom simply cannot recognize the GPU and cannot use the hardware acceleration. When will the new hardware get support?
    Anshul_Saini
    Hi ​@huhan0423,
    Apologies for the delayed response. Based on your hardware, the Intel Core Ultra CPU with Intel Arc iGPU should be supported. However, I’ll cross-check this with the product team to confirm compatibility and whether there are any known issues with this specific configuration.
    In the meantime, could you please help share a bit more information:
    • Go to Help > System Info in Lightroom and copy/paste the full details here
    • Share a screenshot from Preferences > Performance showing the GPU section
    • If you see any message indicating the GPU is unsupported, please include a screenshot of that as well
    For troubleshooting, you can also try:
    • Installing a previous version of Lightroom v9.1 from the Creative Cloud to check if the issue is specific to the latest release
    • Following the steps in this guide: https://helpx.adobe.com/lightroom-classic/kb/troubleshoot-gpu.html
    This will help us narrow down whether it’s a compatibility issue, a driver issue, or something specific to the current version.
    Once I have your system info, I’ll take this forward with the product team and get back to you.
    Thanks for your patience.
    Best,
    Anshul Saini
    huhan0423
    huhan0423Author
    Hi Anshul_Saini,
    Thanks for your reply and kind advice. However, I am using the lightroom non classic version. Also, even in v9.3, it still lacks support.
    Here is the system info I got from lightroom:
    Lightroom version: 9.3 x64 [ 20260407-1929-32efcc0 ] (Apr  7 2026)
    NGL Version: 1.43.0.5
    WF Version: 8.3 5c9a130
    VF Version: 1.0.164.1
    HIL Version: 40501
    CAI Version: c2pa-c/0.6.0 c2pa-rs/0.46.0
    PH Version: 5.2.3
    Adobe GSDK Version: 1.4.0.210
    CR Version: 29.0.0.202506270808_710830c
    Catalog ID: 2e5df340bf204a61aa1322586dcbdbd0
    Operating system: Windows 11
    OS Version: Windows 11 Pro (2009)
    Application architecture: x64
    System architecture: x64
    Computer model: LENOVO 21VG / Intel(R) Core(TM) Ultra X7 358H
    Logical processor count: 16
    Processor speed: 3.6 GHz
    Real memory available to Lightroom: 32272.5 MB
    Real memory used by Lightroom: 1399.9 MB (4.3%)
    Virtual memory used by Lightroom: 1282.9 MB
    Memory cache size: 1994.9 MB
    Internal Camera Raw version: 18.3 [ 2526 ]
    Maximum thread count used by Camera Raw: 9
    Camera Raw SIMD optimization: SSE2,AVX,AVX2
    Camera Raw virtual memory: 0MB / 14088MB (0%)
    Display: 3072x1920
    System DPI setting: 192 DPI (high DPI mode)
    Dark Mode: Yes
    Desktop composition enabled: Yes
    Input types: Multitouch: Yes, Integrated touch: Yes, Integrated pen: No, External touch: No, External pen: No, Keyboard: Yes
    Graphics Processor Info: Unknown
    Graphics Processor Detail: loaded: No, supported: No, compute: No, init: I5_Error, hard: fail_no_gpu2, soft: not_checked, al: No, dl: No
    OS Media Capability: true
    Application Folder: C:\Program Files\Adobe\Adobe Lightroom CC
    Settings Folder: C:\Users\huhan\AppData\Roaming\Adobe\Lightroom CC
    Library Folder: C:\Users\huhan\AppData\Local\Adobe\Lightroom CC\Data
    Does Adobe have a plan to support the new Core Ultra 3 series’ new Xe2 iGPU? Or am I missing some system dependencies?
    Anshul_Saini
    @huhan0423, thanks for the detailed follow-up; that helps, and your understanding here is absolutely fair.
    I checked with the product team, and here’s the confirmed update: the Intel Core Ultra X7 358H (Xe2/Arc architecture) should already be supported.
    Next steps from the engineering side: if the latest Intel drivers are already installed and the issue persists, they’ll coordinate further debugging with engineering.
    Could you please do the following so we can take this forward:
    • Try a fresh GPU driver reinstall
    • Then generate and share a DxDiag report. Steps for DxDiag:
    • Press Windows key
    • Type dxdiag and press Enter
    • Wait for the tool to load
    • Click “Save All Information”
    • Save the DxDiag.txt file and upload it here
    Once you share that, I’ll pass it to the product team, and they can validate how the GPU is being exposed to Lightroom and escalate to the engineering team.
    Anshul Saini
