thegersheyfamily
May 15, 2026 5:45 PM UTC
ai sharpen and denoise WILL NOT WORK. Ive tried multiple versions and it said sorry we have encountered and issue. please help!!
The ai sharpen feature that comes with photoshop is not working. can someone help trouble shoot. Ive installed previous versions, tried opening photoshop via cloud app  and not working either. Asked AI chats and followed the many suggestions but not working. Ive done everything but uninstall and reinstall.
    Per Berntsen
    Per BerntsenCorrect answer
    May 17, 2026 2:25 PM UTC
    Your GPU is an NVIDIA GeForce GTX 1060 3 GB.
    It was released in 2016, so it’s 10 years old.
    From the Photoshop system requirements:
    Graphics card
    • GPU with DirectX 12 (feature level 12_0 or later)
    • 1.5 GB of GPU memory
    • GPU newer than 7 years. Keep drivers updated with the latest from manufacturer's website. Adobe does not test with GPUs older than 7 years.
    Driver information is missing in your screenshots, but the latest Studio driver can be downloaded here: https://www.nvidia.com/en-us/drivers/details/257327/
    If updating the driver doesn’t help, I’m afraid you’re out of luck.
    Your hardware is too old.
    Per Berntsen
    Per BerntsenCommunity ExpertCorrect answer
    Graphics card
    May 17, 2026 2:00 PM UTC
    I think you graphic card is the problem. It does match the minimum system requirements only.
    Recommended is a graphic card with 4GB or more.
    My System: Intel i7-8700K - 64GB RAM - NVidia Geforce RTX 3060 - Windows 11 Pro 26H2 -- LR-Classic 16 - Photoshop 28 - Nik Collection 9 - PureRAW 6 - Topaz Photo AI
    thegersheyfamily
    May 17, 2026 12:24 AM UTC
    Sure if this will be helpful but there was a lot of information on the system info so I just took a bunch of pictures. The odd thing is it will randomly work and then not work again. I can't get it to work now but in the past it has done that. I have installed prior versions I have now uninstalled completely reinstalled Photoshop to the newest version and it is not working whatsoever. Can you please help me.
    D Fosse
    May 17, 2026 10:25 AM UTC
    Just paste the whole thing into a text file. Yes, there’s a lot of info there, that’s the whole point ;-)
    You can also paste directly into a reply here.
    CMass
    May 15, 2026 11:17 PM UTC
    Hey @thegersheyfamily,
    That’s a frustrating error message to run into when you’re just trying to get work done. To help troubleshoot, we’ll need a bit more information about the version of the app you’re using and your system details. Though it sounds like it light be a Graphics Processing Unit (GPU) issue. You can find this by going to Help > System Info. Please copy and paste the information into a text file and attach it to your reply.
    ^CM
    jane-e
    May 15, 2026 5:49 PM UTC
    ​@thegersheyfamily
    I’ve closed this duplicate thread so that volunteers are not answering in two places. Please continue in your other thread:
    https://community.adobe.com/questions-712/ai-sharpen-and-denoise-will-not-work-ive-tried-multiple-versions-and-it-said-sorry-we-have-encountered-and-issue-please-help-1561765?postid=1561765#post1561765
    EDIT: Staff combined the duplicate threads and the lock was removed when they were joined.
    Jane
    thegersheyfamily
    May 15, 2026 5:37 PM UTC
    try to use ai sharpen and denoise and it says sorry we have encountered a issue etc..
    Jul 9, 2026 5:44 PM UTC
    what size is your file? it does that to me on 8000x5400 images too. but when i resize 50% then it works, but image comes out all black. as if someone filled it with all black color. same all black happens if i resize same image to 25% size.
    Anshul_Saini
    Aug 12, 2026 3:23 PM UTC
    Hi ​@jongas,
    Thank you for the detailed information. The combination of the error on full-size images and the all-black output on resized versions points to something specific, so let me help narrow this down. A few things to investigate:
    • When the black image appears, does the Layers panel show any actual layer content (e.g., if you toggle layer visibility, or check the layer thumbnail)?
    • Are you working in a specific color profile (ProPhoto RGB, CMYK) that might interact oddly with the AI output?
    • Does this happen with File > Export > Export As on the resized result, or is it black directly on-canvas after AI Sharpen completes?
    • What file format are your source images (RAW via Camera Raw, TIFF, PSD, JPEG)?
    • Are these 8-bit, 16-bit, or 32-bit images?
    • Are you applying AI Sharpen to a flattened layer or a Smart Object?
    • Does the same thing happen if you duplicate the image (Image > Duplicate), flatten it, and then run AI Sharpen on the duplicate?
    • Are you on macOS or Windows, and do you have the latest GPU drivers installed?
    Let us know the answers to the questions above, and we'll work through this with you.
    Best,
    Anshul Saini
