Camera Raw GPU errors: “out-of-memory” and “unrecoverable” — how to fix? (RTX 5070)
  • October 23, 2025
  • 706 views
Camera Raw GPU errors: “out-of-memory” and “unrecoverable” — how to fix? (RTX 5070 | Photoshop 26.11 | ACR 17.5.1 | Bridge 15.1.2.737)
Hi everyone,
When I launch Camera Raw from either Adobe Bridge or Photoshop, I often get one of these two errors:
  1. “The graphics processor has encountered an out-of-memory error. Due to a run-time error, GPU acceleration has been reverted to Limited for the remainder of the session.”
  2. “The graphics processor has encountered an unrecoverable error. Due to a run-time error, GPU acceleration has been disabled for the remainder of the session.”
Sometimes I get only one, sometimes both in sequence.
My setup:
  • GPU: NVIDIA RTX 5070 (Studio Driver ver. 32.0.15.8157 )
  • Photoshop Version: 26.11
  • Adobe Camera Raw Version: 17.5.1
  • Adobe Bridge Version: 15.1.2.737
  • OS: Edition Windows 11 Pro
    Version 25H2
    Installed on ‎18-‎10-‎2025
    OS build 26200.6901
    Experience Windows Feature Experience Pack 1000.26100.253.0
I’ve already tried updating GPU drivers, adjusting GPU preferences in both Camera Raw and Photoshop, and confirming that GPU acceleration is correctly enabled. The issue still happens intermittently.
Has anyone encountered this or found a stable configuration that works with this setup? Any advice or confirmed solutions would be greatly appreciated!
Correct answer Kevin Stohlmeyer
hi @thebestpic try resettings your Camera Raw prefs:
Hold down the Ctrl key (Win) or Cmd key (Mac) while opening Photoshop/Settings/Camera Raw... and then click "Yes" when prompted to delete them.
Srishti_Bali
Hi @thebestpic,
Sorry for the delayed response, and thank you for sharing the detailed follow-up — it really helps us understand the issue better. Could you please check if the same GPU errors persist after updating to the latest release of Photoshop and Camera Raw?
If the problem continues, please share your System Info from Photoshop by going to Help > System Info… and copying the contents here. This will help us review your configuration and identify what might be causing the issue.
Looking forward to your update!
Srishti
Kevin Stohlmeyer
Kevin StohlmeyerCommunity ExpertCorrect answer
Hi Kevin,
Thanks for your suggestion. I tried the Ctrl + Win shortcut, but it didn’t seem to trigger the reset. However, using Alt + Shift on launch worked correctly and reset the preferences.
I also noticed that Camera Raw disables GPU acceleration only when presets are being toggled ...otherwise, GPU acceleration stays active.
Would you like me to share the logs or any diagnostic reports to help further with the issue?
Thanks again for your time and help!
So, as of now the issue not sorted yet.
Sorry my bad..holding the ctrl key didn't work.
