  • October 31, 2007
  • 680 replies
  • 62292 views
Pete
    tianj39935097
    I also have this issue
    You are welcome, that problem came to light on this threads.
    here is a much shorter read on using wide-gamut monitors on Macs
    > g ballard, "Wide Gamut Monitors" #1, 8 Sep 2008 5:36 pm
    Hello everyone. Great thread.
    I too have a problem with SFW since CS3, which I never encountered before in previous versions of PS.
    Quite simply, when I try to use SFW, the color shifts. If I toggle between the Original and various Optimized tabs in SFW you can see the shift clearly (see screen shots). It is therefore impossible to use SFW.
    I have read and read and experimented with lots of settings to no avail. CS3 SFW is handling color differently than previous versions. Period. Or I've found a bug.
    To prove this, if I take a file (see link below) and do a Save As to JPEG, the colors do not shift. If I take that same image into SFW the colors do shift, plus as you'll see from the screen shots there is a display bug in the Optimized view of SFW:
    http://www.vidiotsvideo.com/whatsnewtest.html
    I don't feel this is a monitor or calibration issue, even knowing these certainly effect output, but regardless of that, how can the same file output correctly using Save As... and be wrong using SFW if there isn't an issue, if not a bug, with SFW?
    Thanks for any help, as SFW is not usuable for me.
    Steven
    August 5, 2009
    Steven
    Well that statement says to me you don't have a calibrated monitor. Photoshop uses the custom monitor profile to display your image correctly on your computer.
    with CS3 you need to convert to sRGB before using save for web. Now that browsers are becoming color managed include the profile.
    If you read this whole thread you would know all this, you would also know that very few people have calibrated monitors so most of the people viewing your images are not seeing what you see, and wide gamut monitors are a bit over saturated. So if you have a Wide gamut monitor that is part of your problem.
    @Ramon
    It is about saving MY eyesight and sanity - I don't give a damn about others. You should see reds and greens on the Dell 2408.
    g
    Many thanks for this thread and your page. I have a Dell 2408 on mac and was going crazy with the cartoon colors. It works well on Firefox3 thankfully, but pretty much in all other apps, it looks idiotic.
    Well I'm glad it's debunked then, and that you took the initiative to tell him. I wouldn't mind to remove the link myself if there was a way I could on here. Btw, it wasn't intentionally posted to reck someones work flow. I ran across it trying to fix my problem, but it wouldn't of helped me anyway. good luck
    As has been said, most Web users have uncalibrated monitors and have no idea what calibration is all about or why one would want it.
    Ramón G Castañeda
    Bald headed men fighting over a comb.
    No one has any control over what any image on the web will look like to web users.
    Food for thought, if Adobe would add a button to F'otoshop preferences "DO NOT IGNORE MY VERY IMPORTANT sRGB MONITOR PROFILE WHEN PREVIEWING IMAGES". No one would be having these problems. Not all monitors accurately display sRGB images right out of the box. Ignoring the profile that fixes this is idiotic! It's like removing your glasses and assuming everyone sees like you do!
    May 30, 2008
    Neil Please remove the link. Its that monumentally bad advice again.
    Crystal this guy is a complete moron. I have popped in and explained to this guy why this is bad. and he still has it up. Do not follow his advice if you do you will have even worse color. What this guy can't comprehend is, if you use your monitor profile as your color space only you will have correct color. Give that picture to me and I have no reference point and if you have a bad profile it makes the problem worse.
    Your monitor profile is for color managed applications to use to display the image correctly within a common workspace. Because everyones monitors are different its the profile that smoothes out the inconsistencies.
    Ann Shelbourne - Here's the thread below then, you decide.
    [link removed by host]
    Quote from link:
    "I've recently begun using Photoshop CS3 and noticed that all of my saved 'Save for Web and Devices' jpgs were coming out differently than they looked in my workspace. I always disable colour management as I don't do any print work and I believe the simplest method for web development and design is to work in my monitor's colour working space. This was working fine in CS2 but for some reason my jpgs were looking different when I'd saved them. I discovered a setting in Save for Web and Devices that is on by default and converts the output to the sRGB profile before saving."
