  • October 31, 2007
  • 680 replies
  • 62292 views
Pete
    I call that Adobe wisdom.
    May 30, 2008
    >I did run across a thread sometime ago mentioning that the save for web in cs3 embeds the color profile srgb.
    Not quite right.
    SFW can (it's optional) CONVERT a file to sRGB before saving it for the web; but it does NOT embed that, or any other, profile in order to keep the file as small as possible.
    To enable the sRGB conversion, you need to check the appropriate box in the SFW dialog.
    I'm trying to solve a profile problem of my own, but I did run across a thread sometime ago mentioning that the save for web in cs3 embeds the color profile srgb. I'm not sure what a difference it makes, but... they said to open save for web and poke around in the settings to turn it off. If I find the thread again, I'll post it. Hope this helps.
    Ramón G Castañeda
    > What on earth are desktop and multimedia supposed to represent?
    Without further clarification from Dell, I would take the multimedia setting to be what the "movie" [or something like that] setting in LaCie and Mitsubishi CRT monitors do, namely apply an ungodly boost in brightness (luminosity) while removing the ability to calibrate the red, green and blue guns separately and individually.
    If it don't have numbers , it ain't s---.
    It's an interesting thread, but not everyone has the nerves of Andee Caron to read it thoroughly.
    I too have an UltraSharp Dell 2407WFP and had the same problem. Once I found the "secret setting" of the monitor image mode (via the "hidden buttons" on the monitor front) and switched it from "desktop" to "multimedia", the screen became whiter and the problem disappeared.
    Eureka then :D I'm actually sending LOTS of people to this thread and urging them to read through the whole darned thing ;) That and a few other threads that seem to have gone through the same steps and inevitably come to the same conclusions :)
    Thanks guys and gals :)
    "and in the end, it's not an issue with anything as it's a miss-understanding of color management and display"
    Exactly, but a lot of people don't want to admit that they don't understand the "problem" and will look anywhere else for the answer. As soon as you "get it" the problem miraculously disappears.
    April 7, 2008
    glad you learned somthing. Even if it was not what you had intended.
    Just wanted to say, as I've just finished reading the WHOLE thread, that it was worth every freaking minute. As much as I've screamed at some of you for your lack of "bedside manners", I was willing to be just as offending to the newer posters (myself included!) that didn't take the time to read through this long winded thread to come to terms with the whole issue (and in the end, it's not an issue with anything as it's a miss-understanding of color management and display)
    I just wanted to add as a life lesson leanred to "read the whole darned threads before posting" ;) It's worth the headache :)
    Thank you.
