  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    Just trying to keep things accurate.
    So many apparently authoritative posts, so much crap.
    I just wet my pants
    Thank God you cleared that up. I haven't slept in three weeks.
    Ramon states:
    b <<Off topic:
    b Lundberg02,
    b que sera sera
    b 'Just a bit of trivia for you:
    b Utter nonsense, despite the luminaries who have sung that bit of Spanglish. >>
    According to Wikipedia:
    Authentic renderings of the phrase "whatever will be, will be" in romance languages include:
    French: "Ce qui sera, sera"
    Italian: "Quello che sarà, sarà"
    Portuguese: "O que será, será"
    Spanish: "Lo que será, será"
    Let it go Ramon - the whole world is F up. There is no point in trying to teach.
    Ramón G Castañeda
    I had the same problem with changing RGB readings, and solved it by DESELECTING "Convert to sRGB" located in the flyout drop down menu (which is located next to the preset drop down menu). This doesn't agree with anything I read, but it works. RGB colors don't change.
    I suspected as much, Ramon.
    Tim: viewed in Safari 3.0.4, on a 17" LCD which displays photographs in rich color.
    Your photographs just don't leap off the screen.
    Ramón G Castañeda
    Off topic:
    Lundberg02,
    >que sera sera
    December 11, 2007
    Lundberg02,
    The first one's a little lighter? It's the ugliest of the bunch. What kind of display do you have?
    The bottom one is what I saw through the lens and I was really pushing the saturation levels on that one to the point I wasn't sure if I'ld overdone it. Are you saying all of them are dull looking?
