  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    I'm pretty sure these Dells have a cable connection that will match up with your Mac. Of course, any provided software would probably be Windows-centric, but you shouldn't need it.
    Wow, thanks, I think the 1907FP might be the way to go. I've heard good things about it.
    Found in the Dell store, for $195 after "Instant Savings":
    DELL
    UltraSharp 1907FP 19-inch Black Flat Panel LCD with Height Adjustable Stand
    Usually Ships 1-2 Days
    Manufacturer Part# DC323
    Dell Part# 320-4568
    Max Resolution: 1280 x 1024 / 75 Hz
    Image Contrast Ratio: 700:1
    Response Time: 8 ms
    And for $214, after "Instant Savings":
    DELL
    E207WFP 20-inch Widescreen Flat Panel LCD Monitor
    Manufacturer Part# CK630
    Dell Part# 320-5123
    Max Resolution: 1680 x 1050 / 60 Hz
    Image Contrast Ratio: 800:1
    Response Time: 5 ms
    I'm sure there are more, including closeouts and refurbs in their store.
    January 18, 2008
    DO NOT BUY A VIEWSONIC!!
    With all the "experts" in here, could someone recommend a fair 19" LCD monitor at or under $200??? Or refer me to a thread that could help... doesn't have to be perfect, but will be used with an older G4 system that is replacing a G3 266 Grape iMac. (It's for the kids!!!)
    Thanks
    OK, then we can now get back on track.
    Ramón G Castañeda
    Neil,
    Just read your admonition after I had posted.
    Ramón G Castañeda
    >Spanish: "Lo que será, será"
    BS.
    Correct Spanish: «Lo que ha de ser, será.»
    "Lo que será" is an unidiomatic, high-school Spanish student mistranslation.
    Of course, if Cheat Ham gets his information from the back of cereal boxes and wikipedia
    Folks, let's please get this topic back on track.
    Thanks.
    Graphics is crap.
    Where have you been?
