  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    >but rather than a constructive debate or conversation
    We've already had about 500 posts of that. Not all of constructive at times, but most of it pointing out the proper method of managing colour to achieve predictable results. Using your monitor profile as your RGB working space is not it.
    December 11, 2007
    I was the one who asked the link be removed because it was such bad advice. I even posted at that blog telling everyone why it was such bad advice.
    paolobaillie, If you actually knew what is going on you would not have posted that link. I sorry you got your feelings hurt with the removal of that link but if you stick with it and actually read some books about color management you will understand why it was removed.
    Ramón G Castañeda
    Hope you come back, Paolo.
    Don't take the deletion of your ill-informed link personally. It had nothing to do with you.
    Hope you take the time to read on color management so you'll find out why that advice would have anyone flying color-blind.
    My reaction to your aggressive rhetorical question is immaterial. I just explained how I felt about it.
    And on that sad note I shall leave the Adobe community to you and the moderators and go and join the real world.
    Adios
    Ramón G Castañeda
    To put it in other terms: not being concerned with the web does not remotely mean not being aware of the process of saving images for the web and, most especially, color management in general.
    Ramón G Castañeda
    Because the s.o.b. who tells me where to post hasn't been born, Paolo.
    The other thing Ramon and Lunberg is that the original post clearly refers to web users so why are you bothering to enter the debate at all.
    Ramón G Castañeda
    Paolo,
    The advice in that link was terrible AND dangerous.
    It does not "fix" a problem at all, it just makes whatever crap you have there look OK to you on your particular monitor and NOWHERE ELSE.
    Any user adopting that asinine method is going to end up with lots of ruined image files.
    If you had read this entire thread, or if you had the most elementary knowledge of color management, you would know that.
    The removal of that thread was a real service to other newbies like you who may have followed that terribly bad advice.
    I don't know who deleted the link, but kudos to that person.
    Bizarre bizarre bizarre
    The replies of the techy elite and the removal of the link above by Adobe.
    FACT - there is a problem that clearly exists for a large number of CS3 users. There is a fix, in language anyone can understand (rather than most of the jibberish posted here), by general consensus the fix works but rather than a constructive debate or conversation - a brick wall of arrogance.
    How predictable.
    Ramón G Castañeda
    Lundberg02,
    Likewise, I'm not concerned with the web in the least.
    But the gray scales on both of my monitors are as neutral as can be, even tough I calibrate and profile to gamma 2.2, 6500ºK and a White Point of 95cd/m^2.
    > I calibrate to 1.8 and 9300 on my 17" LCDS because the gray scale is brown at 3/4 if I don't.
    I'd hate to see that on my monitors. Obviously yo hate it too, or you wouldn't correct for it.
    My comment was only that the LCDs are somehow inherently brown if you're forced to calibrate to 1.8 gamma and 9300ºK to get a neutral scale.
