  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    Ramon, my monitor is fine, my prints match my monitor on 95 brightness copy paper, and I don't give a rat's patootie what web addicts see.
    December 10, 2007
    Thank you for removing it. it was in 522.
    December 10, 2007
    can someone delete the link in post 523 I think. As it is really bad advice.
    >So unlike working with images, I just want to keep my colors consistent across all my sites web pages AND when I go to update the backgrounds in some future version of Photoshop I can be secure that the colors will not change.
    By using your monitor profile, you ensure that there is no way anyone in the future will be able to duplicate the colour (even yourself, if you recalibrate, or your monitor drifts, or you get a new one with a new computer, etc).
    Didn't we already have this discussion and didn't we already point out that that Tancredi website was giving bad advice?
    Anyone know the song, "there's a hole in the bucket, dear Liza?"
    THE main problem with working in a monitor color space is the simple fact that monitor color spaces usually not linear like for example Adobe RGB. Therefore, when you make a color adjustment to an image with a curve or any other color tool, you may be over or under compensating the adjustment because the tools are linear.
    Tancredi advice is awful not only for web work, but for everything else as well. This persons approach to color is to be blind.
    December 10, 2007
    Never ever use your monitor profile as your working space.
    jefbak
    Paolobaillie, Buko:
    The links tips fixed my color problem (though I have not compared with CS1 output yet (will the color be the same as CS1 save for web default settings).
    The monitor selection is always an interesting question for me. In my case here, the issue is with colors generated in photoshop for use as css background .gifs and .png files.
    Perhaps the I should just stick with a generic profile in my case?
    December 10, 2007
    paolobaillie
    that link you provided is very bad advice you should never never never use your monitor profile as your working space. You images will look good on your computer and that's it. They will look like Sh!t everywhere else because nobody else has your monitor profile.
    Greetings
    Trying hard to look beyond the tech fest and unfriendliness of most of this thread - so this is mainly aimed at normal photoshop users who like me have suffered this frustrating problem and just want to get it sorted - the link below had my solution, thanks Tancredi.
    Usual disclaimers - sorry if posted before etc.., this worked for me on my set-up (took about 30 secs) and after testing definitely sorted the problem.
    No I can't tell you why it worked - only that it did!!
    [link to incorrect advice removed by F/Host]
    Ramón G Castañeda
    > I calibrate to 1.8 and 9300 on my 17" LCDS because the gray scale is brown at 3/4 if I don't.
    Then the monitor and/or its calibration and profile are beyond salvaging. :/
