  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    By default, Save For Web in CS1 only strips the profile.
    This means if your file is AbobeRGB or 1.8 MonitorRGB going in, it remains in the same source space going out, but it's going out untagged, without a profile.
    By default, CS3 Save for Web CONVERTS to sRGB and strips the profile going out.
    This means that all RGB produced by SFW default is properly Converted untagged sRGB.
    Ask BigBad to convert your site over to untagged sRGB, that's most likely the issue that needs fixing (not matching the original problem)...
    jefbak
    I am just jumping in the site here at www.smith.edu so I am still getting up to speed. A company called BigBad setup the site and it was updated all this time using default settings in CS1.
    CS1 still works fine so I am going to use that for now, but would like to get cs3 to produce the same images soon!
    I calibrate to 1.8 and 9300 on my 17" LCDS because the gray scale is brown at 3/4 if I don't.
    1.8 also gives me better correspondence between monitor and Epson inkjet on ordinary copy paper, which is exactly what I want. SuperCal delivered rich blacks without looking like fresh manure, too. That app does a nice job of aligning the gammas of the R,G,and B. I don't need a hardware cal because I don't do any color for pay.
    People who agonize over what Joe E-bay will see on his 13" CRT are out of their freakin tiny minds.
    Ramón G Castañeda
    That's what Raven says. :p
    In reality, if there are real differences they must come from an improper color management in your earlier workflow, or in your current CS3 workflow; but any decent, accurately calibrated and profiled monitor should show you the differences if they are there.
    My best guess is a gamma setting problem which would have led you to over- or under-correct the earlier images. It's a very common issue when misguided users calibrate their monitors to 1.8 instead of 2.2.
    Please understand this is just a guess based on experience helping users that have had the issue. Obviously I have no insight into your former or current setup.
    jefbak
    Can you send me the css for that? :)
    So if I look at the results on another monitor I might not see the cs1/cs3 difference?
    Ramón G Castañeda
    Just follow Raven's "advice": get a crappy monitor that won't show you the differences and forget about color management.
    jefbak
    None of this seem to help with my problem of getting different SFW results between CS1 and CS3.
    I have all these CS1 SFW rollovers to update in CS3 and the slight color difference is a real problem for me.
    "make sense?"
    yes
    I have been watching, listening and learning... I think I've got it now. Thanks.
    One concern I have is when testing all this stuff on an Apple Cinema Display, Previewing in SFW area works as expected, WindowsRGB and MonitorRGB and Uncompensated Color now look virtually identical.
    While Softproofing in View>ProofSetup>WindowsRGB looks normal, SoftProofing in MonitorRGB still gives a slight saturation boost. This is with an ACD... which by the way exhibits an image persistence effect that is very annoying, but that's another topic.
    So I guess this means that Cinema Displays are not exactly sRGB perfect, which has been stated here, but it seems much closer to sRGB space than the Dell 2407wfp-HC... make sense?
    December 5, 2007
    "Just be happy you dont work in print."
    Tell me about it! I worked for one of the biggest printers in Tampa Florida. It really sucked!
