  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    I don't think there are ill feelings and arguments. It's a message board full of nut cases that are pretty smart. Take it with a grain of salt and learn not only technical issues, but socialization ones as well.
    Just be happy you dont work in print. Those kinds are the worst to deal with.
    ;o)
    December 5, 2007
    I believe that I now have a pretty good understanding of how SFW works. For me it is essential in web production workflow. The fact that it has taken so long to get to this point of understanding does suggest that better info should be available in the Photoshop help files. Of course Help files have always been notoriously unhelpful...that's why forums like this are such a great resource. It's too bad this particular topic has generated so many arguments and ill feelings.
    No - I am trying to get you to think in a larger perspective. I have no argument other then being irritated and victimized by Adobe releasing features that completely confuse users like in SFW.
    December 5, 2007
    Yes I get it, but it is irrelevant to my point. I strongly suspect that you are arguing for the sake of argument.
    Technically, you are managing color regardless. There are different degrees of managing color. Having the monitor profile is the worst form of color management. A non color managed browser is still managing color, just very poorly.
    get it?
    December 5, 2007
    I think you are playing word games and/or missing my point. What term would you propose I use instead to describe an application that recognizes different colour spaces and handles the appropriate conversion between image data and output devices? I believe that most people call it "colour managed".
    Firefox is not a colour managed application. Safari is a colour managed application.
    What would you replace the term with?
    Raven -
    you need to understand that there is no such thing as no color management. Every image needs to reference a color space. You may not be aware of managing color, but SOMETHING needs to describe the pixels in a document.
    December 5, 2007
    Can you support that?
    While I do not have an official Adobe document saying as much, here's why I believe SFW is not colour managed: the "crappy" display I see in SFW is identical to the "crappy" display I see of the same image in a non-colour managed Firefox window.
    >The SFW preview window (the topic of discussion) is not colour managed, and is therefore by definition, not part of a colour managed workflow.
    Im sorry - this is not correct.
    December 5, 2007
    >the final sRGB image will be the same from a wide-gamut monitor and from an sRGB monitor.
    Only true when viewed in a colour-managed environment. The SFW preview window (the topic of discussion) is not colour managed, and is therefore by definition, not part of a colour managed workflow. SFW doesn't know that the monitor is wide-gamut, so there's no conversion taking place to ensure it displays properly. SFW doesn't factor in an ICC tag...you can embed one using SFW, but the preview window disregards it.
    The image seen within the SFW window is crap, as you say, because it's not colour managed. So, when Peter M asks, "Why am I seeing a crap image in SFW", the answer in his case is because SFW is not colour managed and doesn't know how to display the image properly on his wider gamut monitor. It is however giving an accurate display of how crappy the image will look on his monitor in a non-colour managed environment.
